by HIO Silver on Sun Jun 03, 2012 10:04 pm
If ya use DJM beams, ya might wanna know that DJMs are side-specific.
Also, if ya replaced the radius arm bushings, they take like 80 to 120 lbs of torque. Tightened?
Lastly, roll the truck backwards about 5 feet and they roll it forward to its original spot. The suspension/beams could be in a bind and causing the funky measurements.
70 F100 LB 2WD, 360FE, NP435, 70K original miles
01 SuperCrew 4WD
01 PT Cruiser (DD)
71 Pontiac Lemans Sport Convertible, 350P, TH350, Full Hotchkis/Bilstein Suspension, 17" VN-500s
68 Mustang coupe, 200-1V, C4, Granada discs, 8-inch rear, AR Torque Thrusts
65 Mustang coupe, 289-4V, T-10, SSBC discs, 8-inch rear, Magnum 500s
