King pin changeout
King pin changeout
Postby scotts on Tue Jul 17, 2012 7:45 pm
I was informed that I need new king pins in my '69 F100. Thought I would tackle the job myself. Do I need any special tools to do this?
scotts
Re: King pin changeout
Postby elgemcdlf on Tue Jul 17, 2012 8:15 pm
Yes. You can pull your spindles & take them with your king pin kit to a machine shop. The bushings need reamed to match the pins. If you want to do it yourself you will need a bushing driver to drive the old bushings out & the new ones in. You will also need a reamer to ream them to the correct final size. If your grease zerks are in the spindles & not the caps you will need to be sure to align the hole in the bushing with the hole in the spindle.
elgemcdlf
Postby HIO Silver on Tue Jul 17, 2012 8:45 pm
Save yourself the headaches and have a machine shop do it. Personally, it was worth the $95 I spent.
70 F100 LB 2WD, 360FE, NP435, 70K original miles
01 SuperCrew 4WD
01 PT Cruiser (DD)
71 Pontiac Lemans Sport Convertible, 350P, TH350, Full Hotchkis/Bilstein Suspension, 17" VN-500s
68 Mustang coupe, 200-1V, C4, Granada discs, 8-inch rear, AR Torque Thrusts
65 Mustang coupe, 289-4V, T-10, SSBC discs, 8-inch rear, Magnum 500s
HIO Silver
Postby 69rangerf100 on Wed Jul 18, 2012 11:45 am
i did the job myself and it took me about 3 weeks to do in my free time. partly due to that one of the kingpins would not come out.  if you do this yourself make sure that you have a small torch to expand the ibeam and spindle incase you have a stuck king pin.  if you are just going to use the metal bushings i would really reccommend having a shop do it after you remove the spindle. if you are going to us the plastic bushings you can do all the work yourself.
David
Dream as if you'll live forever, live as if you'll die today - James Dean
Daily Driver - 1998 Honda Accord
Wife's Ride - 2007 Ford Explorer Sport Trac
Project - My Dad's 1969 F100 Ranger 390 w/ 3spd manual coming soon PS, PB, A/C and alot of paint and body work - Miss you Dad
http://s936.photobucket.com/albums/ad208/69rangerf100/
69rangerf100
Postby scotts on Sat Jul 21, 2012 5:53 pm
Thanks for all the info. I will take a look at mine and see. Just need to find someone that can do the job with some knowledge.
scotts
Return to Suspension / Steering / Brakes
