Steering gear leaking heavily
- shortbedCUSTOM
On my way home from work last night I started to notice a whining but really couldn't confirm doing 75mph on the highway. Once I got on the city streets it was evident that it was the power steering. About 3 miles from home it got really loud and steering got noticeably harder. Got home, checked it and it was completely dry. I refilled it and it sat in the driveway for about 45mins while I had dinner. Went out after and the fluid spot on the driveway was larger than a basketball. Reservoir was emptied by at least a 1/4. I got under it and could clearly tell where it is leaking from. It's coming out the bottom of the gear box where the pitman arm bolts. I took a pic but can't seem to get it to upload.
My questions are: Can this be serviced or is it shot? Is this something that someone with a better than average mechanical ability can tackle.
-carlos
- Ranchero50
Re: Steering gear leaking heavily
PS gearboxes are pretty difficult to repair. Sounds like the pitman shaft is loose and needs bearings etc. I'd try to find another.
- shortbedCUSTOM
- Ranchero50
They were the same up through the late 70's if you have a Saginaw. I need a new one for too much play myself. Red head sells them but they are salty.
- shortbedCUSTOM
- Canonman67
I installed new seals in mine and it wasn't too difficult. The kit was only $20 if I remember correctly. You might give it a shot before spending $100s on a new box.
- shortbedCUSTOM
I'll do anything to save hundreds! Any chance there's a tutorial on here or somewhere else?
-carlos
- Canonman67
Yes there is. I'm at work right now but I'll post a link when I get up this afternoon. I also have it as a PDF if you want to pm me an email address.
- Canonman67
Here's the thread I used. http://www.ford-trucks.com/forums/10469 ... build.html
- shortbedCUSTOM
- shortbedCUSTOM
Ok, I think I'm going to attempt to rebuild this thing this weekend. Unfortunately, I'm having trouble finding the rebuilding kit. For some reason the kids behind the counter of the auto parts stores don't know what I'm talking abou . Where can I source said kit?
-carlos
- BobbyFord
You can replace the pitman shaft seals without removing the gear. Pull the pitman arm off, remove the circlip, carefully drill a small hole in the seal, insert a screw into the hole and pull the seal out. There are two seals in there.
- Canonman67
I got mine from RockAuto http://www.rockauto.com/en/catalog/ford ... l+kit,7403shortbedCUSTOM wrote:Ok, I think I'm going to attempt to rebuild this thing this weekend. Unfortunately, I'm having trouble finding the rebuilding kit. For some reason the kids behind the counter of the auto parts stores don't know what I'm talking abou . Where can I source said kit?
- shortbedCUSTOM
- Canonman67
Yeah, it's just a seal kit. I think they list bearings too but I can't swear to it.
