Lug Threading?
colnago
Lug Threading?
Post by colnago »
All,
Are all wheel lugs (and lug nuts) for our trucks, regardless of year, the same threading? Is it the same for F100 vs F250 vs F350? I'm looking at converting to front disc brakes, and am wondering if the lug nuts from my drums will thread onto the disc lugs.
HIO Silver
Re: Lug Threading?
Post by HIO Silver »
I recall some F-trucks were reverse-threaded.. clockwise to loosen.
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
ultraranger
Re: Lug Threading?
Post by ultraranger »
F100 wheel studs are 1/2"-20 RH thread.
Steve
TNIceWolf
Re: Lug Threading?
Post by TNIceWolf »
The lug studs on my F350 are quite a bit larger in diameter than a half ton. They are also a mix of left and right hand threads, There are also a couple of hex sizes that can be used on the F350,
Presently in the stable
1969 Ford F-350 DRW
