Qa1 coil over shocks
sledman3064
Post by sledman3064 »
I am doing a crown Vic swap and I saw that I think it was hackster (i could be wrong) did qa1 coilovers on a crown Vic swap I would like to run qa1 coilovers also my setup question is which qa1 coilovers to use and what spring rate for the coils any input would be helpful thanks
HIO Silver
Re: Qa1 coil over shocks
Post by HIO Silver »
Why don't you post the question in his build thread? Or send him a private message?
http://www.fordification.com/forum/view ... &start=180
Eaton Detroit Spring offers lower/stiffer production springs as well as being able to produce a custom set: https://www.eatondetroitspring.com/
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
