Coil Springs
SemperFi
Coil Springs
Post by SemperFi »
Hello, I have an 1973 F100. I was changing out the coil springs, and I noticed the stock coil springs had what appears to be two stabilizer braces in the spring. My new coil springs do not have this. I am wondering if this is required.
The replacement coil springs I have are Precision Coil Springs.
Thanks you
Outside Diameter (In): 5.436 Inch
Bar Size (In): 0.718 Inch
Bar Size (mm): 18.2372mm
Spring Rate (Lbs/In): 383 Lbs./Inch
Color: Black
End 1 Type: PT-34
End 2 Type: Tangent
Finish: Powder Coat
Free Height (In): 15.940 Inch
Free Height (mm): 404.876mm
Inside Diameter (In): 4 Inch
Inside Diameter (mm): 101.6mm
Installed Height (In): 11.500 Inch
Installed Height (mm): 292.1mm
Load (Lbs): 1700 Lbs.
Load Height (In): 11.500 Inch
Material: 5160H
