Question on rear brakes
JIMO2
Post by JIMO2 »
I have a 1967 f100 with factory 9 inch rear and I was missing the shoe crosslinks (the horizontal bar between the shoes for the parking brake) and the parking brake actuator arms as well. I found some and put them in. I am not positive they are correct but fit in there. I think they are 1-3/4 brake shoes.
My concern is the clearance between the said crosslinks and the backside of the axle flange wheel studs. I only have an 1/8th inch of space for the rotation of the axle. The crosslinks I used were Bendix 316274 as were used in 73-79 f100 and f150.
****If anybody with a half ton has their drums off......please take a look....
-How much space between the crosslink and the axle flange/studs??
Thanks-Jim
Jim
"I love it when a plan comes together"
JIMO2
Re: Question on rear brakes
Post by JIMO2 »
Well...did lots of digging and the 1967 F100 is the last to use 1.75" rear brake shoes. In 1968 they went to 2.25". The crosslinks I would like to use are from 1973-1979 F-100 and F150's....no good for the narrower shoes in my '67. Not being able to get them anywhere, I decided to modify the ones I had. I offset them by a 1/4".
Jim
Post by colnago »
I don't know anything about the half-tons, but you might try Rock Auto for brake parts. Tney were my go-to place for my 3/4-ton.
JIMO2
Post by JIMO2 »
colnago wrote:I don't know anything about the half-tons, but you might try Rock Auto for brake parts. Tney were my go-to place for my 3/4-ton.
Thanks but I did try Rock Auto and the brake shoe crosslink is not in their listing. I was able to locate ONE nos on Ebay but at $35 for it and the fact I needed two, I decided to modify the ones I had. The problem is now solved.
Jim
