Retrofit steering column
Hey guys!
I've been lurking on here ever since I bought a 1969 Ranger with a 360 and c6 transmission about two months ago. So far the work has been going well on it, but I have a question:
The steering column on this truck needs to be replaced. As far as I can tell there are no bearings in it AT ALL (the shaft sort of rattles around in the tube), and also where the collar is supposed to be, below the steering wheel, the tube is all torn up from a column-to-floor shift conversion. I should also mention that the truck has a Bendix power steering box.
I've been searching to find the dimensions for an aftermarket column, hot rod style, but I'm a bit confused as to the length. After some searching, I found comments saying that the length should be just shy of 35", but when I got in and measured myself, I got 4" on one side of the fire wall and 24" on the other. Unless that fire wall is 7" thick, this doesn't add up. Can anybody confirm a length for me?thanks for any help I can get.
Re: Retrofit steering column
Which length? The shaft or the tube? From the bottom of the steering wheel to the end of the shaft? Length is relative to the steering setup. PS vs non-PS, Saginaw vs Bendix, 2wd vs 4wd, automatic vs manual. You can't just say the steering column is X inches long. Your best gauge is to measure from the inside of the firewall to the back of the steering wheel and then from the outside of the firewall to the shaft on the steering gear box then subtract a little for free play and installation. You should be able to adjust everything 1/4"-1/2" once installed. Here's a good article that references some key dimensions. http://www.fordification.com/tech/steering-column.htm
Thanks for the reply. I saw the article you linked, that's the one that gave me confusing dimensions. The measurements I took before and after the fire wall total about 28" when measured in exactly the way you described. The article shows more like 35".
I tried to cover the details you asked about it my original post: c6 (automatic) tranny, Bendix PS, I forgot to mention 2wd. I take your point about tube vs. shaft length, it's just that I usually only see one length given, both in articles and on products for sale. Which length should I be looking at? There are only a couple more inches of shaft beyond the tube on my column.
Something else I forgot to mention: I've been rebuilding motorcycles for a while now, but this is my first cager project. I have a little bit of a learning curve ahead of me. I appreciate all the help you guys can offer.
Here's a helpful page I found during my search: https://www.ididitinc.com/files/pdf/how ... column.pdf
It doesn't explain why my measurements are so far off from the ones in the other page that was linked, but it does give a good basis for making your own measurements in a custom application.
The dimensions in the tech article are in regard to the steering shaft. They refer to the length of the part from the round plate on the bottom, which bolts to the rag joint, to the tip at the threads on the top, which is under the steering wheel horn button. I've marked up the length referred to in this photo. The top one is a PS column shift, the bottom is a non-PS floor shift column, I think. Not sure if either is Saginaw or Bendix though.
Thanks, Sargentrs, that explains a lot. By the way, do you happen to know if the rag joint end of the shaft is a dd end, splined, or just a round end that bolts in place? I found a steering column that may work, but it has a 1" shaft with a u joint set up to fit a 3/4" dd shaft on the PS box.
Or, would it be possible to use a steering column with a 1" shaft and switch out the rag joint? I found many different rag joints, such as this: http://m.ebay.com/itm/POWER-STEERING-3- ... iid%253A13
Does anybody know the shaft diameter and splines for the Bendix PS box?
The bottom end of the shaft is adaptable but the top end is not unless you go with an aftermarket steering wheel. The steering wheel is set up for the stock 3/4" shaft so switching to a 1" will cause you problems mounting the steering wheel. The rag joint end of the steering shaft is splined and swedged after the plate is pressed on. Looking at the end with the plate on it, you'll see an indentation/cavity in the center of the shaft. The shaft protrudes through the plate a little and then Ford used some kind of tool to expand the end of the shaft. Those plates are a bear to get off. To remove mine, I used a pipe welded to a heavy bench, slid the shaft through the pipe, heated the plate cherry red and then slammed the shaft through the pipe. Must've taken 10 passes at it before the plate popped off. My plate was worn out and I had a worn out shaft with a good plate. To put it back on, I had to grind the end of the shaft, press the plate back on the splines and then welded it for security. No reason to think you can't swap out rag joints and shafts, just maintain the length you need and the upper spline and thread for the steering wheel. A lot of people have done the CV swap and used Borgenson style or other U-joint configurations for the steering shaft. Space is at a premium between the steering box and the firewall though so you'll have to keep it compact. You could switch to a U-joint configuration however, the rag joint serves the dual purpose of flexibility and vibration dampening so you'd have to go with a vibration damper style like this Might contact Borgeson and tell them your application http://www.borgeson.com/xcart/catalog/S ... -c-17.html. Might contact Borgeson and tell them your application. The only real difference between the '71+ shaft and the '70- shaft is the length of the threads where the steering wheel presses on. Robroy wrote up a great article detailing the difference and adapting a 3 spoke steering wheel to his '72 http://www.fordification.com/forum/view ... hp?t=35113 (Thanks Robroy!)
Btw, in case you haven't dissected your column yet, here's something I wrote up that might give you so more insight. http://www.fordification.com/forum/view ... hp?t=72274
Thanks for all the information! The stock column I have is pretty torn up, so a rebuild isn't an option. And I already have an aftermarket steering wheel, so if I go with a 1" shaft I should just have to buy a new adapter.
So it looks to me like a 3/4" 36 spline rag joint should fit the shaft of the ps box. If anybody knows otherwise, give a shout. I'll be posting more as I get this build underway.
Looking forward to your updates. This could help a lot of others in the future. Thanks!
If anybody out there is curious, I pulled the old steering column today. It measures 32” from the top of the upper sleeve to the end of the shaft, and the shaft on the Bendix appears to be 3/4-36. So I ordered a nice clean black steering column in black with tilt. I couldn’t find one for Ford at a reasonable price, but I found this link to convert GM to Ford wiring on the column: https://static.summitracing.com/global/ ... -19-11.pdf
The shaft of the new column is a 1” DD style, so I had to order an appropriate rag connection. Also, I think I already mentioned that my steering wheel is after market, so a new wheel adapter should make it work.
The next adjustment I’ll have to make is in the diameter of the column. The stock is 2 1/4” and the new is 2”, so I’ll have to fashion up a spacer, should be easy enough. When the parts come in I’ll let you guys know how installation goes. Maybe this’ll help somebody else.
Watching for your updates!
Well, the installation went pretty smoothly, with a couple small exceptions. Here’s what I did:
The steering column itself has a 2” diameter, while the stock is 2 1/4”. I had to fashion up a sleeve spacer and a new mounting bracket. The spacer was easy enough, turns out 2” PVC was just the right diameter. I cut a short length of it, then put a slit down the length of it so it could be squeezed by the mounting bracket. I made the bracket from 1/8” aluminum, bent to fit the sleeve. I also had to make a small spacer to go on top of the steering column where it mounts to the dash to make it float in the space properly. There is a cowel that sits on top of the column at the dash, and without the small spacer it just didn’t sit right.
I also cut another piece of PVC to fit the clamp on the other side of the firewall. All of this was pretty easy and straightforward.
The wiring was the real bitch. I cut the plug and a length of the wiring from the original steering column to splice into the new wiring. I had a GM to Ford wiring diagram, but the plug on the Ford column wasn’t original, so all the colors were wrong! I had to make a Ford-to-plug-to-GM wiring diagram. I won’t go into details, because none of you will probably have to go through the same thing.
All put back together, all wired up, then out for a drive. I found that with every left turn, the horn gave a little honk. Once around the block managed to offend a few drivers and pedestrians.
I pulled the steering wheel and found that the little ring contact for the horn inside the steering column was rubbing the screw for mounting the turn signal switch. I fashioned a 1/4” spacer to sit behind it, and now everything works properly. The end. Not as easy as it could have been, but not as hard, either. Now let’s get a few pics:
- jzjames
That’s lookin good! Enjoy.
