Hydro boost with stock ford master cylinder?
briansbronco
Post by briansbronco »
OK this new 69 f250 4x4 is needing a master cylinder. Knew it when I bought it and have a new one in the box to go in it. Here's the question. When adding hydro boost, can I use the stock drum brake master or do I need to change it out for something else? Looking forward the truck will be getting a 4BT Cummings diesel and a ZF5 transmission. Not for a while until I can assemble parts.
I know I'll need to add a power steering pump but that's not hard to do. I already have a hydroboost setup that I believe will work fine. My truck is manual steering and is likely to stay that way. Even after the diesel swap.
1970 F250 4x4 SC Flatbed.
1968 F350 DRW Service body.
1969 F250 4x4 SC DRW
"People sleep peaceably in their beds at night because rough men stand ready to do evil on their behalf"---Orwell
Manny
Re: Hydro boost with stock ford master cylinder?
Post by Manny »
You should be able to install a master cylinder onto the hydroboost. In past with broncos have had some master cylinders work terrible on some hydroboost. One 74' bronco i know of actually wound up working best with a corvette master cylinder. You best bet is to put it on see what you get. Question is why stay manual steering with all that other work? :? Seems power would be the best choice. especially with a heavy 4BT :thup:
briansbronco
It might get swapped at some point, I'm just not going to be in a hurry about it. I have everything to do all the upgrades here I think with the exception of the core 4bt. That will take a little doing. I was a Cummings certified tech before retirement. I want a smooth as silk 4bt that makes about 170 hp.
Manny
Post by Manny »
I did not know a smooth a silk 4bt existed :lol: . I'm a Detroit guy fiddle with Cummins as well but 4bt is not my forte so take your word for it. Didn't some have balance shafts like the 50 Detroit some not???? :?
briansbronco
I built a balanced and blueprinted 4bt that you could sit a coke can on top of and it wouldn't make it fizzy....LOL I want to do another one. The only major drawback to them is heat. They produce a LOT of it. I see a ton of them in builds but most are folks that don't know their eye from a hole in the ground so I can't blame them. They just don't know any better.
Manny
Post by Manny »
That's impressive. I have not done too much work on them. Most of my stuff i've worked on is 8.3c and bigger n14 855 some ancient 743's. But i am a powerstroke, Detroit Diesel guy. Nothing wrong with the little cummins just have not really built one. Hope you find a core would love to watch that build! :thup:
briansbronco
Yeah I got some parts to put on the chopping block to hopefully fund it. All I need is a buildable core and my machine shop.
