4x4 crossmember?
4x4 & Off-road Forum Archives
Moderator: Doug Comer
zakt
4x4 crossmember?
Post by zakt »
Anyone know if that 4x4 crossmember is bolt in on a 2wd frame? Wondering if I should put one of those in my conversion from 2wd to 4wd.....(probably doesnt matter but looks alittle more beefier)
Todd
1972 Ford F350 crewcab
Wes
Post by Wes »
The cross member is different on a 4x4 so the front differential will not hit it. I think, but am not sure, you will have to move and or replace the front cross member.
here is a picture I have of mine
http://www.fordification.com/galleries/ ... ?pos=-5808
Wes
67 F250 High boy
69 Bronco
zakt
re: 4x4 crossmember?
Post by zakt »
sorry didnt specify, the transmission crossmember. The 2wd engine crossmember will stay I will have a 12 1/2" lift in front, plenty to clear the 2wd engine crossmember :D
averagef250
Post by averagef250 »
The 4x4 crossmember will bolt in, but it'll be at the wrong angle. 4x4's use an additional plate riveted inside the frame rails for the crossmember to sit on.
460 crew
Post by 460 crew »
Mine were bolted on. Image
