transmission swap
4x4 & Off-road Forum Archives
Moderator: Doug Comer
averagef250
Postby averagef250 » Tue Aug 14, 2007 7:18 pm
You can put a 435 or t-18/19 in there real easy, but they're still 3 gears, you just get a granny to play with when needed.
With a 460 a late model ZF S5-42 is a bolt in, but you have to lose the 24 t-case and go to a mated t-case.
gbrett
Postby gbrett » Wed Aug 15, 2007 2:02 pm
average f250 why cant you use a 2wd zf with the 24 case just have to either shorten or lengthen the drive shaft to take up the difference I would think any 2wd trany that will bolt up to the 460 can be made to work
Return to “Archives”
Who is online
