Is this a power steering box for a 4WD? (pics included)
4x4 & Off-road Forum Archives
Moderator: Doug Comer
JWW
Postby JWW » Fri Feb 08, 2008 4:56 pm
I have been reading the section on coverting a 4WD to power steering. I found this one at a salvage yard. I'm not planning on using since my truck is a 2WD, but I wanted to make sure it was 4WD only before I passed it up.
JWW
1967 F100 Ranger, Auto, 240ci
2004 F150 Crew Cab
My project: viewtopic.php?f=22&t=23983&st=0&sk=t&sd=a
Doug Comer
re: Is this a power steering box for a 4WD? (pics included)
Postby Doug Comer » Fri Feb 08, 2008 6:24 pm
:thup: Good eye. That looks to be a power steering box from a half ton becuase of the coil spring front suspension. I'm sure somebody is actually looking for that box. Doug
1967 f100 4x4
1970 f250 4x4
willysrul
Postby willysrul » Sat Feb 09, 2008 6:17 am
X2 on the 1/2 ton.
Looks almost identical to the one I got from a 79 Bronco.
It does however appear to be just a tad longer up and down though.
67 HiBoy - 390/435/TS'd205 HPD60f/FFD60r welded 3.54's 36x12.50x16 TSL radials
50 Willys P/U (project) - 302/435/205 FFD60r
averagef250
Postby averagef250 » Sat Feb 09, 2008 8:49 am
That's the 76-79 F-150 4x4 box.
The casting number you posted is off the torsion valve assembly. It reads as a 67 part number because the valve is the same from 68 through 97.
These boxes are a popular swap for EB's and obviously F-100 4x4's. Most swaps require you to swap out the ballnut for one that works in the opposite direction.
Return to “Archives”
