np 540-go
Moderator: Doug Comer
- Wes
np 540-go
Just found a 64 gmc 400 w/ 305c and a np 540-?? in it. I am wondering how well it will work in a high boy.Any one have any info ??
Wes
67 F250 High boy
69 Bronco
If you can't see fit to stand behind Our Troops...Please stand in front of them
67 F250 High boy
69 Bronco
- averagef250
The 540's a real nice tranny. I like them a lot. Just like a 435, but much bigger bearings and a dream to work on.
If the 540 was overdrive it would be hot deal, but they aren't. The shift pattern is a little strange for a 5 speed and the ratios aren't necessary unless you're pulling big weight.
I rebuilt a Ford 540 last week and re-ratiod it and removed second gear to make it a 4 speed and added a ranger splitter in front of it all behind an isuzu 6BD1T in a 77 F-350.
- averagef250
I got to thinking how I might be wrong about the non-overdrive and I was. The 540 was made in an OD version, the 540-O, but they aren't very common and they didn't hold up well. The 540-O was a 540 with a different input-cluster ratio for a .82 overdrive. Apparently the larger diameter input gear puts about 18% more load on the input shaft which thends to snap them off behind engines with any real grunt. The downer is you can't buy NP540-O input shafts anymore.
If you found an NP540-O or just a 540 or 541 you can swap the guts directly into your NP435. I don't know how it would work, the top shift plates are different and AFAIK, Ford never used the 540-O, only GM and dodge so the 540-O's that are out there can't work with a Ford clutch.
- Wes
Cool thanks for the info I saw that there was only 1 od unit listed out of @ 7 diff gear ratio combinations. This tranny has re builders tag on unfortunately the re builder went out of business. So I suppose it could be any ratio now.
Wes
67 F250 High boy
69 Bronco
67 F250 High boy
69 Bronco
