F-100 VS F-250 4x4 Front Axle
4x4 & Off-road Forum Archives
Moderator: Doug Comer
Customize
Post by Customize »
I just wanted to verify that while the F-100 4wd front axle used coil springs, the F-250 4wd front axle used leaf springs. Thanks!
averagef250
Post by averagef250 »
You're right. The only exception to this was the 78-79 F-150 4x4 supercab which used leaf springs.
Doug Comer
re: F-100 VS F-250 4x4 Front Axle
Post by Doug Comer »
Dustin I've never owned one, but didn't the slick side half tons use leaf springs up front? I thought they did but can't remember. Doug
1967 f100 4x4
1970 f250 4x4
Customize
Post by Customize »
I'm not sure what a slickside is, but the 1961-66 trucks did have coil springs starting in 1965. Although, I am not sure if that was on both the 2wd and 4wd trucks. Every generation before that had leaf springs.
averagef250
Sorry, forgot 66 WAS the first year for coils on the F-100 4x4. Before that they were leaf sprung too.
