Dana 44 ball joints
4x4 & Off-road Forum Archives
Moderator: Doug Comer
James72
Dana 44 ball joints
Postby James72 » Thu May 22, 2008 8:09 pm
I popped the ball joints out of my dana 44 today and it looks like the top one is either adjustable or had some sort of sleeve threaded in it, if it's adjustable dose anyone know the procedure? Also how is the top ball joint retained in the knuckle, it dosen't look like I can press it either way cause there is a step on both sides, it's pretty rusted though I may be missing something. Thanks, James
'05 Mustang GT
'72 crew 4x4
'07 KTM 450 xcw
2006 F350 CC Diesel 4x4 Lariat
James72
re: Dana 44 ball joints
Postby James72 » Fri May 23, 2008 8:07 pm
I got the new ball joints in, they were just built up with rust so it only looked like it had a step, and apparently the upper threaded bushing is for preloading the ball joints now all I need is a special socket and a torque spec. :roll:
James
'05 Mustang GT
'72 crew 4x4
'07 KTM 450 xcw
Wes
Postby Wes » Sat May 24, 2008 4:14 am
take that old sleeve out you should get new ones w/ new BJ's . Thread the new sleeve in part way install the knuckle w/ new bj's tighten down the lower I believe torque is @ 80 ft pnds. Now you will need the a spanner socket to fit the sleeve torque the sleeve down to 50 ft pnds install the upper ball joint lock nut your done.
Wes
67 F250 High boy
69 Bronco
James72
Postby James72 » Sat May 24, 2008 6:53 pm
yep, that was exactly right, it went together pretty easy
now the next problem, I put my spindle in the parts washer and it came out without and needles left in the bearing for the drive axle.
Nobody can find them and Ford says to measure it, anyone have one? Id like just a part number then I'll just go to the bearing store and skip Ford, save some $$$.
James
'05 Mustang GT
'72 crew 4x4
'07 KTM 450 xcw
fordguy_78
Postby fordguy_78 » Mon May 26, 2008 10:46 pm
I would just go to http://broncograveyard.com/bronco/i-22148_spindle_bearing_repair_kit.htm that should be what you need
Phill
78 Mustang
67 F250ish
2010 F250 Harley Davidson
James72
Postby James72 » Mon May 26, 2008 11:04 pm
ok now I have the bearing in, every thing set up and....
When I unlock the hub it gets real tight towards the end, then when I unlock it the dog clutch wont engage right away, If I tap it with a hammer it locks in right away, almost like the spring is weak. It also feels like the knob is pushing the hub in too far when releasing the dog clutch.
This is an axle I've never used so I don't know if it was like this before.
Anyone had a similar problem?
And thanks fordguy_78 that is exactly what I needed :thup:
James
'05 Mustang GT
'72 crew 4x4
'07 KTM 450 xcw
Return to “Archives”
Who is online
