led dash lights
Re: led dash lights
WOW! Those look awesome! I'll definitely have to look into those.
- alvald83
Re: led dash lights
Are they just plug and play? How many are needed for our dash?
Re: led dash lights
Those look amazing. Did those just go right in or did they need an adapter or something? How many are needed?
- amycyclenut
Re: led dash lights
Plug-n-play - standard 1895 socket (round base). I don't remember how many bulbs I needed. You can check the schematics and figure it out.
1967 F100 352 3spd w/OD
- Pat Crash
Re: led dash lights
On my stock dash lights, the lights brighten and dim depending on my acceleration. Have you experienced that with these LEDs?
1971 Ford F100 Ranger XLT Long Bed — 360 with C6 Automatic — 9" with 3.00 Gear Ratio
- amycyclenut
Re: led dash lights
It's been a while since I've driven the truck at night. I didn't notice it then. Maybe someone else will have a more definitive answer.
- Gray035
Re: led dash lights
I bought these ones. Four bulbs will replace the bezel lights and the turn signal lights. You would need a fifth if you want to replace the high beam indicator (I didn't want to buy another four just to replace that one). In my truck these dim as well. They are plug and play...a REALLY easy upgrade.
http://www.ebay.com/itm/281416329427?_t ... EBIDX%3AIT
1968 F-250 Camper Special
Re: led dash lights
Mr Gray , I just want to make sure before I order.
My truck is a 1972 Ranger XLT , is this the correct bulb for my instrument cluster?
Thank you.
Thank you.
Re: led dash lights
some people have said that when you put leds in your dash or in the taillights that you have to change the flasher on the fuse box? is that right or can you just leave it alone?thanks for any help on this.
- SmokeyBear
Re: led dash lights
Dash lights no. Tail lights... maybe. If you have an "electronic" flasher, you'll be fine, if you have the old "load" type flasher, they will not flash, They will come on and stay lit.lilorbie wrote:some people have said that when you put leds in your dash or in the taillights that you have to change the flasher on the fuse box? is that right or can you just leave it alone?thanks for any help on this.
70 F-100 XLT
"Christine" Gone but not forgotten.
72 F-100 Ranger XLT
72 F-100 Ranger XLT
Re: led dash lights
Sweet, I was wondering what LEDS would do for my truck?
- Bullitt74
Re: led dash lights
Extremely cool. Thanks for this!
Steve F.
Red Deer, Alberta, Canada
Re: led dash lights
HiPo Parts (http://www.hipoparts.com/1961-79-ford-t ... sion-kits/) offers an original "coke bottle" green. We've used the HiPo Parts and Mustang Project on vehicles on the show and both are decent. I personally really like the original look.
- Timd
Re: led dash lights
Anyone know if they sell a version that would fit in a 1969 f100?
1969 Ford F100 Custom Cab
302
302
- MadJoe
Re: led dash lights
Awesome, thanks for the link. Just bought the $20 Factory Color set for my Bump. At least 1/3 of my dash lights are out, so this was needed anyway.Autorestomod wrote:HiPo Parts (http://www.hipoparts.com/1961-79-ford-t ... sion-kits/) offers an original "coke bottle" green. We've used the HiPo Parts and Mustang Project on vehicles on the show and both are decent. I personally really like the original look.
TimD, check the link to HiPo Parts in Autorestomod's post, they have filters to make sure you get the right parts. Good luck!
1971 F-350 DRW SWB Stake Body
360 FE
C6 transmission
OEM disc brakes
OEM power steering
Dana 70 4.10 rear end
360 FE
C6 transmission
OEM disc brakes
OEM power steering
