What is this?
69f100 tx
What is this?
Post by 69f100 tx »
My truck just has a pefect hole, apparently I had one of these and it was removed at some point. IDK how to even search for this. So what exactly is this thing, what purpose does it serve? My truck had an auxillary fuel tank which was removed years ago so my thought was that it was somehow related to that. :fr: Thanks in advance!!
Casey
SeapineF37
Re: What is this?
Post by SeapineF37 »
yep you are right. thats whre the selector valve for the fuel line went. allowed you to manually control which tank the fuel was being drawn from. probably was removed when the aux tank was eliminated...
69Ford
Re: What is this?
Post by 69Ford »
Fuel tank selector valve. Your truck came with duel tanks.
69f100 tx
Re: What is this?
Post by 69f100 tx »
Thanks guys!
Agskam
Re: What is this?
Post by Agskam »
Sorry that this is unrelated to your question but would you mind sharing where you got your dash/gauge set up, do you like it, and how did you set up the speedo? Thanks in advance.
