Factory style rubber floor cover
Anyone know a part number for the factory rubber floor cover for our trucks? Not sure if I want carpet in mine and the ones I see reproduced don't go beside the seat like the original one's. Does anybody make one like the original piece? Thanks
- jzjames
Re: Factory style rubber floor cover
Don't think so, but some will say they are available.
I wished there was a good reproduction like the one my 67 had,... with the lightning bolt!
- TNIceWolf
There are two types of rubber mat available for your truck. However you must know what to order. There are two types of Humps in the floorboard. A low hump which is a welded in construction and a high hump which is a bolted in trans tunnel. Each one of those determines the mat you will need to order. Most often the part number you will find available only applies to the low hump. It takes some work to find the high hump variant.
Presently in the stable
1969 Ford F-350 DRW
1969 Ford F-350 DRW
Dennis Carpenter has them. You have to get one for a dent side era, The floors are the same as the bump sides.
I bought one for a 8" Tunnel hump and the mat goes from the fuel tank to the firewall. There's plenty of extra material to trim to fit.
P.N. D7TZ-1013010-K for the 8" trans hump. $200
It comes with the padding for the floor board on each side, But you have to make you own padding for the trans hump.
Heavy duty and has a nice fit.
Hazelnut, would you happen to have some pictures of the rubber floor mat you installed in your truck?
I would like to put the rubber mat back in mine if I could find one that covers the floor like the original one did.
Pictures would be helpful before I buy one and don't like the look of it. Thanks
- Ranchero50
I installed a factory rubber mat over carpet. Kind of luxurious while being practical. I also love the lightning bolt emblem on the mat
1968f250429 wrote:Hazelnut, would you happen to have some pictures of the rubber floor mat you installed in your truck?
I put mine in but have not cut to fit yet. It's just laying in the floor relaxing. I'll take a picture for you if you want to see what it looks like just being laid out.
- BobbyFord
Yes I would still like to see some pictures of your mat in your truck so I can still get an idea. How much are those mats? Where do I aquire one at? Just my local dealer I guess? Thanks
