bulb for heater control
jf100
Post by jf100 »
Does anyone know where the bulb for the heat and defroster goes so I can see them in the dark? I have bulb hanging down but have know idea where it goes. Thank you for your help.
Nitekruizer
Re: bulb for heater control
Post by Nitekruizer »
It goes into the back of the controls. You may have to pull the switches/controls out of the dash to put it in. Not difficult, maybe 1/2 hour job at most.
mulletmobile
Post by mulletmobile »
Here you go. This shows a pic of were it goes. Mine was hanging loose behind the glovebox.
You can also check this Thread for when I found mine.
http://www.fordification.com/forum/view ... 59#p719059
The real pain is that the bulb has to go in from the top. So if your radio is in you will not have fun, but it is possible to do it. Good luck and let us know how it goes.
1971 F-250, Wimbeldon White, 360, PB, dealer add-on A/C (A.R.A. brand), 1970 coded interior (23 - Med. blue/Light blue) with 42,000 miles.
