Fender liners...
Fender liners...
Postby mk on Wed Sep 24, 2008 10:03 pm
Whilst in the midst of a front brake job, the sun warm on my shoulders, my mind began to wander as I looked up under the front fenders. Got thinking about where all that water, snow and slush is gonna end up in the not too distant future for those of us that wanna drive our trucks anywhere north of Oregon. Also got thinking about all those virginal cab mounts I've seen on '77-'79 dentsides so I went and picked up a set of fender liners from one of those trucks to see if they'd fit.
Turns out the arch is bigger on the newer trucks. With a little time spent trimming and remolding, they'll actually fit pretty well. I just need to get the heat gun to make the bottom curves match the bump fenders.
Now my cab mounts, outer fenders and upper inner fenders are protected. Kind of late for these ones but the replacements will last longer when I get around to restoring it...
mike
Always drink upstream from the herd...
~Will Rogers
Mercury truck ID thread:
viewtopic.php?f=2&t=35331
Ford truck model history:
viewtopic.php?f=2&t=37394
Using dentside fender liners:
http://fordification.com/forum/viewtopi ... =7&t=35675
Matchbox diecast bumps:
viewtopic.php?f=2&t=45618
mk
Re: Fender liners...
Postby floyd67 on Thu Sep 25, 2008 9:44 am
the last time we spoke you said you were going to that. how long did it take?
1967 f1oo "floyd"
2002 f-150 DD
2007 fusion (wife's car)
floyd67
Postby mk on Thu Sep 25, 2008 12:32 pm
To this point, barely half an hour...
Helps to have a warm day or shop so they're flexible. Trimming the edge for decent fit starts with tapering in from the bottom screw hole on each end as you can see on the pic to a depth equivalent to the inside edge of the rest of the holes. With care in fitting, they'll look pretty good. This was just a quickie experiment to see if they'd actually work.
mike
~Will Rogers
mk
Postby FLATBEDFORD on Fri Sep 26, 2008 5:24 pm
I have a set from an '86 that I plan to use eventually. How did you attach them?
Steve
1970 F350 DRW Factory 9' Platform/Stake, 360, T18
2000 F250 XLT, 4x4, Supercab, V10, Auto
2006 Focus ZX3 SES 5spd
2006 Volvo S60 AWD (Mrs. FLATBEDFORD)
Driveway full of Ford (kinda)
My Photo Gallery
http://s115.photobucket.com/albums/n298/flatbedford/
FLATBEDFORD
Postby mk on Fri Sep 26, 2008 6:07 pm
I just kept the screws that held them to the donor truck and reused them, Steve. For the inside edge I might have to use a small bolt throught the inner fender.
mike
~Will Rogers
mk
Postby mljjones67 on Fri Sep 26, 2008 9:31 pm
This is a sweet upgrade.  have it on my list now!
MIKE J.
1967 cab and dump flat bed on 1979 f-250 4x4 frame. 4bt Cummins . diesel zf-5 transmission. NP 205 Transfer case. Dana 60 HP. Rear Dana 60. 6" suspension lift. 16.5 stock style rims 10" wide with 35" tires.
My Project Thread
mljjones67
Postby truckguy on Fri Sep 26, 2008 9:45 pm
I have aways wounder if they would work.
Kyle
Image ImageImage
1986 F-150 300
1972 f-250 360 PS,PB
1970 F-350 360 PB
1969 f-250 390 CS,ranger, PS,PDB,AC
1968 F-350 360 PB
1968 f-250 360 PB
http://s222.photobucket.com/albums/dd207/truckguy_02/
truckguy
Postby My427stang on Fri Sep 26, 2008 9:49 pm
I have had later model liner on my 71 in since the early 90's.  They work great and undoubtedly the best thing you can do to protect the cab mounts in a place that salts the roads, it will prevent rust.
The second place is the back of the cab, they also had plastic panels that protected the back of the cab corners.  I did NOT put those in the first time, and I am paying on this restoration.  The cab mounts lasted beautifully, the cab corners and inside panels disappeared.
71 F-100 SB 4x4, 445 FE, RPM intake, 750 Holley, 4 speed, 4 inch softride lift, all poly bushings, Duraspark, integral PS, most mods installed since the 80's (except the 445!)
07 HD Streetglide, 96 cid, 6 speed
08 F-250 6.4 Crew Cab SB 4x4
My427stang
Postby mk on Mon Sep 29, 2008 12:02 pm
Great avatar, 427. I sent some parts to a guy near Charlotte one time and got him to send me an HM tshirt.
Steve, we're in the middle of a body swap on dad's '85 4x4 and I had a look at the fender liners. If I were you, I'd get some pre '80 liners. They will be a lot less work to fit   :doh:
mike
~Will Rogers
mk
Postby basketcase0302 on Mon Sep 29, 2008 4:22 pm
MK,
Good stuff man. :thup:
I've got a set from my 79' that I was gonna ebay, guess I won't now.
Basketcase
viewtopic.php?f=22&t=46251
http://s240.photobucket.com/albums/ff13 ... t%20build/
71 F-350 dually flatbed, "little 302" (as some folks here call them) .030 over V-8 with a "baby"C-6, B & M "ghetto" truckshifter, Dana70/4.11 ratio, intermittent wipers, tilt steering, full LED lighting on the flat bed, and no stereo yet (this way I can hear all the rattles to diagnose them)!
Postby FLATBEDFORD on Mon Sep 29, 2008 5:02 pm
I didn't know the pre '80 trucks had them. They would surely work better than the '86 ones. I'll have to keep an eye out for 'em.
Steve
My Photo Gallery
FLATBEDFORD
Postby mk on Tue Sep 30, 2008 4:13 pm
It would have been great if they started using them earlier. They started in the '77 trucks.
mike
~Will Rogers
mk
Return to Body & Paint
