The 2-screw bezels will fit, they mount differently using a 1-1/2" oval countersink screw, using the lense holes.
They also cover the lense a bit more than your 3-hole bezels.
The shorter screw is for the lens only, pan head/knurled about 1-1/8"?
If you haven't seen the two side by side, there here, scroll down, the '68 and '69.
http://www.fordification.com/tech/67-72ID_01.htmHere's the 2 screw type:
I wonder if they will cover the 3 mounting holes around your taillights, should you use those?
