Bump Fender
Bump Fender
Could someone tell me if the Fender from a Dent side Truck lower rear are the same as our Bumps. Wanted to see if I could use this to patch my fender that's in need of repair
Re: Bump Fender
No .
If it's just the bottom it's easy enough to bend up a patch.
Re: Bump Fender
Thank you for the reply don't think I have the tools make the bends need for a lower patch panel
Re: Bump Fender
A vise and a couple pieces of angle iron, or the edge of a work bench, and a hammer can do a lot.
Re: Bump Fender
You can buy reproduction lower fender patches that are already the correct shape
