Unknown hole in floorboard/firewall
Arroz
Post by Arroz »
My searching has not turned up the origin of this passthrough, other than allowing water under the mat to start the ever so slow oxidation process :wink:
hazelnut
Re: Unknown hole in floorboard/firewall
Post by hazelnut »
That's the hole for the clutch rod to go through the floor board. If it was a automatic it would have a plate on it.
:yt: I went from a 3 spd on the column to an automatic. I took a piece of aluminum flashing, fabbed a gasket, coated it with RTV and used sheet metal screws to cap it off.
Arroz
Post by Arroz »
Thanks! Seal it back up!
