solvent
Busboy
solvent
Post by Busboy »
Does anyone know of a solvent that will dissolve 50 year old 3M weatherstripping adhesive without taking the paint off?
1967 F-100 4x4 custom cab.
Jacksdad
Re: solvent
Post by Jacksdad »
I'd start off with something fairly harmless like WD40 and some elbow grease.
Re: solvent
I've had marginal success with Good Off on my '64 Fairlane's vent window post seal removal. Soaked a rag and pressed it on it firmly for a few minutes then used a plastic scraper to get the bulk of it off. Rubbing with the soaked rag removed the rest. Tedious but got it all off.
Bronco_77
Re: solvent
Post by Bronco_77 »
I've had perty good luck with 3m adhesive remover and it doesn't take much a can of it last forever.
68 f100 390 3 speed on the collom G maw gave to me G paw drove in late 70s till late 80s
77 bronco 302 lifted 5.5 with 33s and rears cut
69 Mustang boss 302 clone bought when was 14 sold when was 28 to build house
Busboy
Re: solvent
Post by Busboy »
Thanks for the suggestions, I think I'll see if some store around here has the 3M.
Re: solvent
WD40 and goof off should work. Never played with the 3m stuff.
Ohiotinkerer
Re: solvent
Post by Ohiotinkerer »
:yt:
Goof Off worked great on both the old glue on the weatherstripping, house paint splatters and rattle can over spray that was all over everything when the drivers door was replaced on mine........ :thup:
1997 Honda CBR 900RR
Busboy
Re: solvent
Post by Busboy »
Well I tried goof off, the gel type that stays on overnight. It didn't do jack or squat! I have never gotten goof off ever to work. I'm throwing it away. :cuss:
Ohiotinkerer
Re: solvent
Can't vouch for the gel......never used it - always used the liquid stuff...... :?
jzjames
Re: solvent
Post by jzjames »
Don't know of a solvent that you can wipe off that hardened up weatherstrip adhesive. Removing all of it is going to take some intense elbow grease.
Wipe it with any solvent like lacquer thinner to try to soften it. Then you might have to sand off the surface of the glue and repeat with the solvent rag until it all washes off. You can try some sort of scraping tool, together with the thinner on a rag. Make sure you've got ventilation too. Have fun!
Busboy
Re: solvent
Post by Busboy »
Brake cleaner and a Scotchbrite pad worked as well as anything.
