Ford Grill
patruccio
Ford Grill
Postby patruccio » Thu Jun 01, 2017 8:39 pm
I have a 68 camper/special and recently had the grill polished, do
I need to clear coat the grill? The folks that polished the grill did
a >>>>??>>> job, so I did the best I could to clean it up. Any info
would be appreciated. :fr:
lilorbie
Re: Ford Grill
Postby lilorbie » Sun Jun 04, 2017 4:55 pm
i would use a good grade of clear coat. like the kind that is used to paint our trucks. i would also use more than one coat. good luck.
patruccio
Re: Ford Grill
Postby patruccio » Thu Jun 08, 2017 12:17 am
Thanks for the info.
patruccio
Re: Ford Grill
Postby patruccio » Fri Jun 16, 2017 8:52 pm
Not possible says auto body shop-best to just apply wax. :yes:
patruccio
Re: Ford Grill
Postby patruccio » Sat Jul 29, 2017 7:03 pm
That's what my body shop suggested-WAX
chicof100
Re: Ford Grill
Postby chicof100 » Sat Jul 29, 2017 9:45 pm
Aluminum 101. You can anodize but you can't clear coat. Anodizing is a thing of the past thanks to the EPA. but there are polishing and sealers on the market. I do not care who you halve talked to if they say you can clear coat, they don't know what they are talking about. For those of you who think otherwise, you don't know squat. I've been doing aluminum for over ten years mainly grilles, I know there is nothing out there to "Coat it with" other than a sealer. I've invested a ton of money learning secrets. Nothing is cheap but at the same time, nothing is expensive, unless your learning. I know a while back people were talking about doing body work on a grille. They suggested using wood and such...... I laughed and argued about how to deal with aluminum, but idiots know better. So I keep my talents under wraps. My grilles are show quality but that's another story.
1964 f100
292 yblock
1969 Ranger
Loving all ford vehicles
FFRKing
Re: Ford Grill
Postby FFRKing » Sun Jul 30, 2017 10:45 am
I had a friend who spent a lot of time polishing his old school aluminum wheels to a bright, shiny finish. He took them to another friend at a body shop who did all of the cleaning prep work and clearcoated them using the the best materials and equipment. They looked just like new and absolutely beautiful, for about a year and a half. He drove the car on a regular basis but avoided the really nasty weather when possible. The clear coat started to lift and they looked like the Chevy cars from the 80's. He talked to a couple of body shop guys who have a lot of experience and they all just shook their heads at them. They suggested he strip and repolish them and find a good aluminum sealer. Polished aluminum does not have a good surface for the clearcoat to bond to.
ChicoF100, do you have a good sealer that you recommend?
Chris
-1968 F100 SWB, 4.6 3V, 5R55S auto, Crown Vic front and rear.
-1968 Cougar XR-7, 351C, AOD, Explorer rear. In approx. 6,000 pieces at the moment.
Ohiotinkerer
Re: Ford Grill
Postby Ohiotinkerer » Tue Aug 01, 2017 11:15 pm
I've been using Wizards Power Seal for the last 2 years on the polished frame on my '97 CBR900RR and like it - being bare aluminium its gonna require attention but has really helped on the frequency of doing it!
http://wizardsproducts.com/power-seal-8-oz/
1968 F100 Baseline 2wd - Rangoon Red - 360 2bbl - T18 - power steering and manual brakes
1997 Honda CBR 900RR
1977 MonArk 14 ft jon boat with a 1963 Johnson JW-18 3hp outboard
Return to “Body & Paint”
Who is online
