67 F100 - CV Swap - Bed Questions
crazzmc
Post by crazzmc »
Hi everyone I am new to this forum, but have recently been thinking about the CV swap for my 67 f100. I see a lot of people doing it, but everyone has a hump in the bed. I'm trying to figure out if it's possible to do it without it.
Thanks.
Figuring out this whole restoring process with my 68' F100.
BrockGrimes
Re: 67 F100 - CV Swap - Bed Questions
Post by BrockGrimes »
The CV swap is the front suspension. Unless you're asking about swapping in a cv rear end. You can run the stock 9" rear, a 8.8 out of an explorer, or anything else but some require more work. The 8.8 is basically a bolt in job.
Check out this build:
https://www.youtube.com/watch?v=qbEUHpR ... qRIukEYTAg
If it's not broke, MOD IT!
1972 F100 short wheel base, 302, C6, 9"
poke em
Post by poke em »
The ones you are seeing with a hump in the bed are full body swaps on to CV frames.
Ozblitz
Post by Ozblitz »
The other reason you're seeing 'c' notches or humps, is because the leaf springs are swapped from over the axle to under the axle.
