F700 donor cab
stacerbob
F700 donor cab
Post by stacerbob »
Can a f700 can be used for a donor for a good rust free cab? Or are the floors and mounts different? Haven't looked at one, thanks
mk
Re: F700 donor cab
Post by mk »
It could if you want to do some surgery on the firewall and upper front floor. The column comes through at a steeper angle and the front mounts are different.
mike
Always drink upstream from the herd...
~Will Rogers
Mercury truck ID thread:
http://www.fordification.com/forum/view ... =2&t=35331
Ford truck model history:
http://www.fordification.com/forum/view ... =2&t=37394
Using dentside fender liners:
http://fordification.com/forum/viewtopi ... =7&t=35675
Matchbox diecast bumps:
http://www.fordification.com/forum/view ... =2&t=45618
stacerbob
Re: F700 donor cab
Post by stacerbob »
ok thanks, thought it might drop on like the older chevy cab. They are usually a lot better in terms of rust.
mk
Re: F700 donor cab
Post by mk »
Here's a pic showing what you'll have to modify...
mike
~Will Rogers
