Side Molding Plastic Clip Replacement
pchelp101
Post by pchelp101 »
How do these plastic clips come off? I have a 69' with a bed molding that has fallen of, the plastic clips look like they are riveted on at the factory? :?
1969 F100, 390, 3 Speed, 2WD
cdnwillyg
Re: Side Molding Plastic Clip Replacement
Post by cdnwillyg »
Yes there should be 10 that rivet on and one front one that bolts on. And the small rear trim has 4 screws to hold it on.
Stony Plain, Alberta, Canada
:drive:Willy
pchelp101
Post by pchelp101 »
Just wish there was way to put the new clips back on the OEM rivets.
cdnwillyg
Post by cdnwillyg »
pchelp101 wrote:Just wish there was way to put the new clips back on the OEM rivets.
Not sure what the issue is here, drill and re-rivet? :hmm:
:drive:Willy
pchelp101
Post by pchelp101 »
cdnwillg, when I think about the chance of the drill bouncing off the rivet all I see are big scratches in my paint job ! :cry:
Put masking rape around the
To protect the paint. Use side cutters to cut the rivet flage off. Use a punch to tap the rivet back through the hole.
