67 turn signals stopped working...
Carb
Post by Carb »
So I was driving and noticed the turn signals seemed....slower than usual. After a minute they both stopped working. Strange....
Other than checking the fuse, What are the next logical troubleshooting steps? I have read several forum posts so far but none are quite the same as my problem....Wondering if the symptoms of them slowing down then stopping completely are any clue?
Thanks in advance,
Carb
Re: 67 turn signals stopped working...
Carb » Wed May 24, 2017 2:21 pm
Thanks in advance,
Carb
Check your front and rear bulbs and locate the turn signal flasher behind your dash, (could still be clipped into the instrument panel where they came from the factory-but it's usually dangling behind the dash around the steering wheel).
You can see the flasher here in the upper right of this pic:
Carb
Post by Carb »
Thanks in advance,
Carb
Thanks, do you mean the flasher itself may be busted?
Yes, all they are is a simple bi-metallic strip with a set of "points" inside that heat up to break the circuit / then cool down to close the circuit.
They wear out pretty frequently, it's also a cheap part if that the issue. :thup:
Carb
Post by Carb »
Thanks! will check. not sure how to though :? I am pretty handy with a voltmeter but just enough to get into trouble.
Charlie67f100
Post by Charlie67f100 »
I agree check this and check you stop light switch on the brake pedal if the brake pedal if that button on the switch ain't getting pushed in far enough to satisfy it. They to can cause a pain with the turn signal went through this with my 67.
Here's the wiring diagram that might help you with following the power on the turn signals. Start at the fuse and go from there but what you've described is common for the flasher being the culprit. I'd throw a new flasher in it, (they are a cheap part that every auto parts store carries) before I spent hours tracing and following the wiring.
