First, the Bendix box didn't exactly "drop" into place - it was quite a struggle. I had to slide the steering wheel into the cab as far as it would go and when all was back together the column sticks 1" farther into the cab and there is a gap between the wheel and column. But the wheel turns fine and doesn't bind.
The real problem is that the pump pulley doesn't line up with the crank pulley. This setup must have come off a truck with a/c as the pulley looks like it would line up with a 3 groove crank pulley.
Did they make multiple pump pulleys? and will a pulley of any similar year ford product work?
Anyone do this swap and have similar problems?
thanks,
John
