1967 stepside daily driver.
Postby killakobra on Thu Jul 02, 2009 1:40 am
today i bought a fairly strait '67 stepper from a guy who was going to build it for his wife but she lost interest.  no engine , breaks need redoing ect  but i have all of that stuff to transplant over from my 72 LWB. enough with the talk and on with the pictures.
this shows the side spare tire mount and the dent in the fender for it.
i like the bumper
the cab is fairly clean.  there are a few holes in the floor board but nothing i can't fix quickly
as you can see there is rust but most of it is only on the surface.  also, the paint looks like it may be salvageable.  for those of you keeping count, this is bump number 3.
:fr:  for keeping my interested.
1967 f100 stepside 300ci I6
1969 f100/600 stepside retro truck -under construction-
1972 longbed trailer
killakobra
Re: 1967 stepside daily driver.
Postby SteveC on Thu Jul 02, 2009 3:57 am
good looking truck and lunar green to boot
I don't really care about brands Chevy Ford Dodge ...as long as it doesn't sound like two old dudes farting in a coffee can.
http://s169.photobucket.com/albums/u223/imabaka70/ Projects listed on the left side
WOOOT!! i passed my mechanics classes. Now working as a mechanic and waiting to go for my ASE certifications.
1967 f-100 4x4
1969/72 f100 351w EFI m5r2 5 speed
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
SteveC
Postby rjewkes on Thu Jul 02, 2009 5:37 pm
killa what part are you in of this Great nation :lol:
fuelly.com
rjewkes
Postby killakobra on Thu Jul 02, 2009 7:47 pm
western nc :P
killakobra
Postby killakobra on Thu Jul 02, 2009 7:48 pm
western nc :P.  it all looks the same though.
killakobra
Postby killakobra on Fri Jul 03, 2009 3:12 am
sorry for the double post, i was having some funky connection problems.
anyways, back on topic.  polish is awesome. when we were unloading the truck from the dolly, we were leaving hand prints all over the truck.  you can probably see this in the above photos.  this intrigued us and got us thinking "will this paint clean up?"  yes, yes it did.
what do you guy's think?  i've been all of it once with meguiar's ultimate compound and alot of the drivers side and hood a second time.
killakobra
Postby 1971ford on Fri Jul 03, 2009 3:59 am
no way that is the same truck....
:eek:
-Ryan
1969 F250 4x4 - Frame-off rebuild, Cummins, built 518, Flatbed, 4" lift, 37" tires, and much more
Build Thread: viewtopic.php?f=22&t=26870&start=840
SOLD -1971 F100 Offroad Race Truck - 429C.I., ATO fully built c6, 22" wheel travel, Engine/cab/bed cage, 35's, hydraulic bump stops, coilovers, Alcan leaf springs
Build Thread: viewtopic.php?f=22&t=33697&st=0&sk=t&sd=a&start=615
1971ford
Postby killakobra on Fri Jul 03, 2009 4:06 am
1971ford wrote:no way that is the same truck....
:eek:
crazy isn't it?  but it hasn't been inspected in 23 years so i doubt it's seen much sun.
killakobra
Postby hotrod ford on Fri Jul 03, 2009 7:16 am
that is insane. nice lookin truck.  :thup:
1971 Sport Custom SWB: 360/C6 3.00
1965 Ford Falcon 4Dr: Inline 170 3sp
hotrod ford
Postby mljjones67 on Fri Jul 03, 2009 8:18 am
The milky layer is just the paint oxidizing.  Once that is gone the real paint shines through.  I have shined up hundreds old paint jobs just like that one.
Makes all the work worth while. :wink:
MIKE J.
1967 cab and dump flat bed on 1979 f-250 4x4 frame. 4bt Cummins . diesel zf-5 transmission. NP 205 Transfer case. Dana 60 HP. Rear Dana 60. 6" suspension lift. 16.5 stock style rims 10" wide with 35" tires.
My Project Thread
mljjones67
Postby killakobra on Fri Jul 03, 2009 8:36 pm
yea, i'm please.  we've done alot of work on it up to this point.  we pulled the front right wheel and noticed the king pins were wobbly so we decid3ed to pull the front end out of the 72 since it's been rework completly and stick it under the 72.  we've also got a new throw out bearing, master cylinder (they changed them between then and 69  :cuss:)  new radiator, new break lines for the front, new wheel cyinders, new shoes, and it came with a new set up tires.  well, at least ones that havn't seen many miles.  we're half way through the front end swap and half way through the break change.
killakobra
Postby killakobra on Tue Jul 07, 2009 4:13 am
alright.  we've got the front end changed, the front brakes are hooked up(still have the back ones to check),  the engine is in, the battery is in, clutch is working, shifter is smoooth, and the drivers door closes right now. we still have to flush the tank out, install the gas line, finish up the wiring, get a horn, find some tail lights (maybe i can find the ones off of the other truck.), mirrors need to be acquired, back shocks need changing..... that's about it. oh, and the radiator is still out of the truck. hopefully i can finish it today.
killakobra
Postby killakobra on Wed Jul 08, 2009 11:46 am
back with some more updates.  we've gotten the differential switched out and most of the bakes hooked up.  the steel line under the truck blew out when we were bleeding the brakes and now we have to get a replacement (the only lines that we can't use off of the 72 LWB). the newer rear end also has wider brakes that match the front end we put in it. hard to imagine that those narrow shoes would stop that truck  :hmm: .  We also picked up a new set of shocks for the back because the other set of new shocks we have don't mount right (a lot of things about the 67 are different.....) .  since we had the stock wheels off, i decided to try out some of the others i had laying around.  which ones do you think i should use?
this
or this?
but in all seriousness we're close to starting it.  i have to pick up a rear seal for the tranny and some odds and ends and then we're cranking it.
here is a shot of the new diff. and shocks.  pretty isn't it.
killakobra
Postby rjewkes on Thu Jul 09, 2009 12:13 am
mljjones67 wrote:The milky layer is just the paint oxidizing.  Once that is gone the real paint shines through.  I have shined up hundreds old paint jobs just like that one.
Wished i had known this with both the 77 nova i had when i was 18 and my first f100.
The nova was GM Fawnskin(copper metalic) and milky i blcoked and shot a low grade  rattlecan that looked half decent  metalic cobalt with ghost flames. but a revived original paint job woulda looked nicer.
And the first f100 was tu-ton Metalic Seqouia brown over wimbeldon white. Also very faded. Agan did the painting  but this time without the prep looked worse than the nova. So factory paint woulda been nicer.
and yes killa very nice. again whe your ready i'll let you wotrk on mine won't even charge you for it :lol:
fuelly.com
rjewkes
Postby marvin2 on Thu Jul 09, 2009 9:35 am
Good golly...you are moving fast with this one.  I can't believe that paint job buffed out like that!  Great Work!
marvin2
Next
Return to Project Updates
