my green 68
Show us your rides or projects!
Re: my green 68
Postby tybob81 on Sun Oct 17, 2010 5:01 pm
newly covered 95 f150 seat.
1968 swb hydroboost w/4 wheel discs, ididit tilt column, p/s, all led lights, Vintage Air and painless wiring. F.A.S.T ez efi 5.0, Built AOD. Addco front & rear sway bars, Custom wood bed floor. Full frame off resto-mod.
1968 Crew cab shorty 393w, M5R2, Vintage Air, 4 link and cv front suspension, hydroboost w/ 4 wheel disc brakes...under construction.
tybob81
Re: my green 68
Postby tybob81 on Sun Oct 17, 2010 5:03 pm
Dusty engine compartment.  Doing some rerouting of the painless harness.
tybob81
Re: my green 68
Postby Zorm on Fri Oct 22, 2010 7:53 am
how did you do the wood in the bed?
Zorm
Re: my green 68
Postby tybob81 on Fri Oct 22, 2010 8:33 am
I built new rear and center crossmembers and modified the front crossmember.  Made a track on the sides for the wood to slide into also.
tybob81
Re: my green 68
Postby BiggDogg on Fri Oct 22, 2010 10:33 pm
Wow, that has got to be one of my top 10 favorite bumps.  Very, very nice.    :thup:
1970 F250 Camper Special
"Its no coincidence that man's best friend can't talk."
BiggDogg
Re: my green 68
Postby 72biggreen on Sun Oct 31, 2010 8:50 pm
BiggDogg wrote:Wow, that has got to be one of my top 10 favorite bumps.  Very, very nice.    :thup:
:yt:
72biggreen
Re: my green 68
Postby undertakerman on Tue Jan 04, 2011 5:13 pm
I like your color. Green is one of my Favorites. I'm restoring a 68 Flareside 8' bed and I'm painting it Sassy Grass Green which is a 69-70 Mopar color. I use to have a 69 Roadrunner that was Sassy Grass Green with Black interior. This interior will be Black on Green. Good looking truck. You did a great job.
You know man can live alone, but he cannot live without Peanut Butter and Grape Jelly.
undertakerman
Re: my green 68
Postby 72shortbed on Mon Jun 06, 2011 9:34 pm
Great looking color. And awesome work on your truck. I only hope I can do that well on mine.
72shortbed
Re: my green 68
Postby wwjd63 on Mon Sep 26, 2011 7:18 pm
tybob81 wrote:[ Image ]
:eek: that is the coolest green i have ever seen. :clap:
wwjd63
Re: my green 68
Postby jreyes on Tue Sep 27, 2011 11:01 pm
nice color and it looks that u have done a great bodiy work also!!!
jreyes
Re: my green 68
Postby tybob81 on Tue Sep 27, 2011 11:15 pm
Thank you.....I have a ton of hours blocking this truck till it was straight as an arrow.
tybob81
Re: my green 68
Postby Calvin Gunter on Wed Sep 28, 2011 5:34 am
Hey tybob81,
I see you have a tilt column in your beautiful truck, what brand and part number did you use?
Any problems with the install ?
TIA,Calvin
1967 Ranger,Short bed,390,C-6,9 inch,4 BBL.,intake,cam,headers,3:55 Posi.,A/C,Power steering,Power Disc Brakes,Automatic trans.DJM dropped I-beams,flipped rear hangers,headlight harness upgrade.ExTang tonneau cover "Old Blue".
http://s508.photobucket.com/albums/s328/BigSxy96/
1967 Base model,352,2bbl.,3 on the tree,short bed,3:25 9 inch "Rusty".
1967 Mustang coupe-show car/garage queen.Small Block,alum. heads,Nitrous,4:11Locker,Areospace brakes "Mystang".
1996 F-250 Powerstroke-Big intake,exhaust,injectors.(Nice Smoke Show) "Big Sexy"
Calvin Gunter
Re: my green 68
Postby tybob81 on Wed Sep 28, 2011 5:39 am
It is an early IDIDIT column for a 67-72 truck.  It is the metal housing one.  I think they have a ford plug now, nut this one had a gm plug and o made an adapter plug from an old column to plug a gm into a ford painless harness.
tybob81
Re: my green 68
Postby Calvin Gunter on Wed Sep 28, 2011 5:56 am
Thanks tybob81,
Do you remember the part number you used?
I see they have a retro fit for our trucks.
Was yours a direct bolt up or did you have to modify anything other than the wiring.
TIA,Calvin
Calvin Gunter
Re: my green 68
Postby tybob81 on Wed Sep 28, 2011 6:01 am
Bolted right up an as far a a part number I can look....been over 5the years since I bought it.
tybob81
PreviousNext
Return to Photo Gallery
