69 crew highboy UPDATE: 300 install coming along
Re: 69 crew highboy UPDATE: 3/19/11 Tires and Wheels
Postby Fordnatic on Sat Sep 03, 2011 5:41 am
Don't drive on the snow with those tires!!  With that rib in the middle and bias ply construction there is nothing with less traction in slick conditions.
70F100: 410 Merc with tri-power, close ratio toploader, 4.56 detroit locker 9"
68F100 4x4: 390, 4 spd/NP 205, Rancho 4" urethane susp, 35x12.50 All Terrain T/A's
55F100
01F150 Daily Driver: TP tunes, AF1 intake, elec fans, Magnaflow exh, underdrive pulleys, Centerlines
Fordnatic
Postby fomocoguy on Sat Sep 03, 2011 10:02 am
Well I don't drive her in the snow so I should be ok. You can't see it in the pictures but I also went ahead and cut sipes across the center section of each tire about every 1/8 to 1/4 inch with a razor knife before I installed them. I've driven it in the rain a few times and it has plenty of traction with the sipes.
Joe
1969 F250 Crew Cab 4x4
2000 Jeep Cherokee Classic w/3" lift
fomocoguy
Postby FoPAR on Sun Sep 04, 2011 12:22 am
Very cool, I like em! :thup:
FoPAR
Postby CrypticRacer13 on Tue Sep 06, 2011 10:28 pm
Looks killer man, im loving those tires an wheels
-Mike-
ECV 1849
Build>http://fordification.com/forum/viewtopic.php?f=22&t=68225&sid=e48912912d8c55dfd241961be3310f21
69' F250 Highboy 390ci.,NP435,Dana 24,HPD44,D60
67' Dodge Coronet R/T 440ci.4speed,D60, all numbers correct
72' Dodge Dart 440ci.727,D60,10ptcage street strip on meth 10.40s
05' Dodge Ram Qcab. 392ci.Hemi,Runs 12's, Wifes whip an baby hauler
12' Ford Focus Titanium Hatch Back, Gas saver for the work week
CrypticRacer13
Postby fomocoguy on Sun Feb 19, 2012 9:58 am
Well, once again it's been awhile since I've updated this thread so her goes for all you who follow this one but maybe not others I've posted. For almost three years now  I've been building a stout 300 six for the old gal. The thread is here: viewtopic.php?f=3&t=46269 The build is just about complete. In the next week or so I should have it mounted on a test stand and be breaking her in. Here's a couple shots of how it sits now:
The specs on her are as follows-    9.0:1 compression
                                                  Crane 901 torque cam
                                                  EFI split manifolds
                                                  500cfm Edelbrock
                                                  Clifford aluminum intake
                                                  Head lightly ported and unshrouded exhaust valves
                                                  .022 copper head gasket for tight quench
                                                  crank turned, bored 30 over, head and block decked
                                                  Dizzy recurved
                                                  Newer block with 1 piece rear main, older head with adjustable valvetrain
Hopefully I'll be wrapping it all up and installing it within a month or so.
Joe
fomocoguy
Re: 69 crew highboy UPDATE: 2/19/12 300 build near completion
Postby averagef250 on Sun Feb 19, 2012 11:31 am
I know some guys that use 6x6's for work and they hate those NDT's.  They say you can spin all 6 tires with 100 HP on a rainy day. Let the clutch out on a hill and 30K of truck and trailer goes backwards!
averagef250
Postby fomocoguy on Sun Feb 19, 2012 1:28 pm
averagef250 wrote:I know some guys that use 6x6's for work and they hate those NDT's.  They say you can spin all 6 tires with 100 HP on a rainy day. Let the clutch out on a hill and 30K of truck and trailer goes backwards!
Maybe it's because they are newer and not OE tires, but that hasn't been my experiance at all. These are made by DENMAN, and they have been great. I was out in a downpour just a few days ago and was scared about taking off from a light on a serious incline and had no slippage at all. I would like to say that all the sipes I cut in them are the only reason, but I think they must have a little softer compound than the OE ones from back in the day. Either way, these work great.
Joe
fomocoguy
Postby FormerMarine1981 on Sun Feb 19, 2012 4:04 pm
Nice looking 6 you have there. Keep up the good work.
What we do in Life, Echoes in Eternity
FormerMarine1981
Postby fomocoguy on Sun Feb 19, 2012 5:23 pm
FormerMarine1981 wrote:Nice looking 6 you have there. Keep up the good work.
Thanks! Hopefully it runs as good as it looks. :pray:
Joe
fomocoguy
Postby fomocoguy on Sun May 20, 2012 10:21 am
Well, it's alive! I posted a build thread in the engine catagorie, but for those of you who haven't seen it here's a couple vids. I fired it up last night for the first time, and it sounds awesome! Crank up the volume for full effect.  8)
http://www.youtube.com/watch?feature=pl ... aAPp3VPOdU
http://www.youtube.com/watch?feature=pl ... m8uQQVn-sY
Joe
fomocoguy
Re: 69 crew highboy UPDATE: 300 six build done and ALIVE!
Postby XABN82 on Sun May 20, 2012 9:53 pm
Man that thing sounds great.
XABN82
Postby tylerb43 on Mon May 21, 2012 6:57 am
Wow, awesome job, man! I never knew a 300 could sound so good! Congrats!  :thup:
tylerb43
Postby Manny on Mon May 21, 2012 9:22 pm
Sounds very good.  Gotta love the efl manifolds they are the only way to go!!! Also love 0:50 in the first video. Cannot tell you how many times i have popped myself. Also done a ton with gas in the eyes as well. Gotta wear the safety glasses!!!! Now you just need that thing in the truck!!! :thup:
Dapper Dan
67' F-250 CS high boy
360 4 bbl
4 speed
d44-d60 4.10 gears
http://www.truebluetrucks.com
Manny
Postby fomocoguy on Tue May 22, 2012 6:55 pm
Thanks guys! I can't wait to get it in the truck. Hopefully I can get a day this weekend to at least yank the 360 and start cleaning things up. :D
Manny wrote: Also love 0:50 in the first video. Cannot tell you how many times i have popped myself. Also done a ton with gas in the eyes as well. Gotta wear the safety glasses!!!! Now you just need that thing in the truck!!! :thup:
I knew I was in a bad spot, but I was too determined to change my set up once I realized I was over the top of the carb. I wanted to hear that baby run, and it was getting late, eyesight be damned... :lol:
Joe
fomocoguy
Postby Manny on Thu May 24, 2012 9:14 pm
fomocoguy wrote:Thanks guys! I can't wait to get it in the truck. Hopefully I can get a day this weekend to at least yank the 360 and start cleaning things up. :D
That is one good thing about fords the distributer being out in front of the carb. However it still winds up with flame blobs and the smell of burning nose hair. One thing is for sure now that after putting efi manifolds on my bro's 300 i will never suggest headers on one to anybody. The manifolds are the way to go. You get it in need to get a story together on the big crew big six it will be a good one for pages.... :thup: That is a sharp looking 300 for sure!!!
Dapper Dan
360 4 bbl
4 speed
d44-d60 4.10 gears
Manny
PreviousNext
Return to Project Updates
