#1 done. Now, on to #5.
1.
check DANA 44 12-bolt knuckles2. replace slow leaking master cylinder brake lines
3. replace minor leaking DANA 60 rear pinion seal
4. remove trailer brake switch and lines
5. fix non-op TEMP gauge
6. drag link ball joint rubber bushing missing NAPA $80!, lube ZERK fittings (need needle adapter)
7. replace/fix rear leaf springs
8. fix power steering fluid spitting onto inner fender
9. need side view mirrors
10. change to '67 sunvisor mount rearview mirror ('65-66 Mustang alternative)
11. fix non-op park lights
12. fix horn
13. add speedometer cable or go electric speedometer later until new transmission
14. swap in electric fan
15. replace 2.25" exhaust pipes, add mufflers or hold off until new motor
16. fix window cranks
17. fix bench seat track or bucket seats
18. fix parking brake cables or drive-line brake
19. buy air compressor
20. remove inner fenders rust; 67-79 donor or front roll cage - chromoly $$?!
21. replace rusted radiator core support; 67-79 donor or front roll cage - chromoly $$?!
22. remove roof rust, weld
23. remove floor rust, weld
24. remove cowl + firewall rust, weld
25. remove door rust, weld
26. remove bed rust or scrap; rear roll cage bed - chromoly $$?!
27. remove stock antenna, fill weld hole
28. hood lock
29. add spare tire rack; junkyard
30. add saddle tanks; junkyard
31. hydro-boost brake system
32. kill switch
33. A/C
34. match ignition key; pin mod
35. headlight harness upgrade
36. alarm
37. utility roll-bar if there's a stock bed
38. dual battery setup
38a. add radio
WISH list:
39. on-board air compressor
40. GPS tracking
41. winch
42. 2.5 ton Rockwell axles
43. wheels; double bead-locks
