1967 stepside daily driver.
Re: 1967 stepside daily driver.
Postby killakobra on Thu Apr 05, 2012 1:05 pm
i picked up a rust free set awhile back for $100 at a local yard. i gotta do a little work on one but nothing major. Still working the reimbursement issue out. i'm thinking about taking the money and painting both fenders and the hood myself. i can't be too mad tho, i scraped a car a couple months back and i'd be a hypocrite to be too angry. i'll keep you guys informed on the whole thing. in the mean time i'm working on getting a set of disk brakes to go upfront. i was wondering if a slightly shorter kingpin than called for would work. i know the 67-74 kingpins are like 1/8 or so shorter but they are the same diameter. so would a 75-79 spindle work with the 67-74 kingpins since all of the support is on the wedge?
1967 f100 stepside 300ci I6
1969 f100/600 stepside retro truck -under construction-
1972 longbed trailer
killakobra
Postby killakobra on Sat Apr 07, 2012 1:06 am
found a 74 extended cab today at a junkyard and bought the spindles and backing plates along with all of the mounting hardware for $100. sounded a little steep but i needed them now. the place looks like it may be a treasure trove for bumps and dents. they have a whole row left and right with pretty much just those to body styles. probably 80 trucks in all. The place is called Vick's classic auto parts and cars. The address is 815 Rutherfordton hwy Chesnee S.C.  I have rotors, calipers, brake hoses, and pads coming in This morning and i hope to have it all together by lunch if my right side spindle comes off as easy as the left.
killakobra
Postby killakobra on Sat Apr 07, 2012 1:57 pm
They are in and they work great. i have yet to use a proportioning valve and i haven't done any real hard stops so i don't know how crucial it is. and talk about cutting it close. i have 1/4 inch clearance between the caliper and the wheel.
killakobra
Postby killakobra on Wed Apr 11, 2012 6:40 am
had the brakes drag a bit the other day and rotors have a slight blueing on them right now. The truck started to bog and then i could smell pads. it fixed itself when i lifted up on the brake pedal so i think it may be a bad master cylinder. As far as the blueing goes i've read that it's normal in the bedding processes due to high initial temps and the crosshatching on the new rotors. it still stops great and there is no pulsation.
killakobra
Postby killakobra on Sun May 27, 2012 11:08 pm
why of why does my motor want 22 degrees of time? and no the balancer hasn't slipped. verified by looking at piston tdc.
killakobra
Postby elgemcdlf on Mon May 28, 2012 11:55 am
Sounds like you are off a tooth on the distributor or timing chain.
elgemcdlf
Postby killakobra on Mon May 28, 2012 1:19 pm
checked with a timing light to verify that i'm indeed at 22 degrees and i have timing gears.
killakobra
Postby elgemcdlf on Tue May 29, 2012 5:51 am
Just because you have gears doesn't mean you can't be off a tooth. 22 degrees sounds way too familiar to me. Just can't remember why. Might be the distance of a tooth on a distributor. Is this causing a problem? I have seen engines require up to 35 degrees but they are usually pretty well modified.
elgemcdlf
Postby killakobra on Tue May 29, 2012 9:18 am
It just seems odd that it need 22 degrees all of a sudden. a couple weeks ago it would bach at anything more than 12 in a nasty way. not if i'm under 16 it will barely run.
killakobra
Postby elgemcdlf on Tue May 29, 2012 12:42 pm
killakobra wrote:It just seems odd that it need 22 degrees all of a sudden. a couple weeks ago it would bach at anything more than 12 in a nasty way. not if i'm under 16 it will barely run.
Points or electronic ignition?
elgemcdlf
Postby killakobra on Wed May 30, 2012 1:29 am
electronic. Duraspark 2 with a stock CDI coil.
killakobra
Postby sargentrs on Wed May 30, 2012 4:43 am
I had a similar issue with 302 when I swapped to Duraspark.  I had broken an advance spring in my points distributor without realizing and she ran like crap so swapped in the Duraspark.  I was unable to get it running well at, what I considered, the "correct" timing.  It was only after I said to heck with the initial timing and set it for 35* max timing at 2500 rpm and she ran like a top at all speeds and idle.  The initial then fell in at .... wait for it..... 22 degrees!  I couldn't accept it so fiddled with it for another 2 hours and came right back to the 22* initial and 35* at 2500 rpm setting.  Set the timing at max and let the initial fall where it wants to.
How come when your wife or kid's Japanese cars break down, it's always the beat up ol' Ford truck that comes to pick 'em up?
1970 F100 Sport Custom Limited LWB, 302cid, 3 on the tree. NO A/C, NO P/S, NO P/B. Currently in 1000 pcs while rebuilding.
Stolen on March 2006 - recovered and returned May 2007. I am truly blessed.
Project thread: viewtopic.php?f=22&t=59995 Plan: 351w, C4, LSD, pwr front disc, p/s, a/c, bucket seats, new interior and paint.
Postby elgemcdlf on Wed May 30, 2012 9:46 am
Sounds like it may be the answer as long as it runs ok. A running engine is fuel, compression & spark at the correct time. What that time is really is irrelevant as long as she runs well.
elgemcdlf
Postby killakobra on Wed May 30, 2012 7:17 pm
it only worries me because it happened all of a sudden. i ordered a new dizzy and it'll be in tomorrow morning. i think the mech advance may have some damage to it.
killakobra
Postby killakobra on Thu May 31, 2012 8:55 am
well, the new dizzy works better but it doesn't solve the 22 degree problem. is there any way a 300 could slip cam timing without completely eating the timing set? it's gear to gear and there are only 2 so i figured if it jumped a tooth it would strip the gears.
killakobra
PreviousNext
Return to Project Updates
