elgemcdlf wrote:I love you with all my heart but you broke my heart chopping your frame like that.
RCF100 wrote:i am currently starting the same swap I got the cv front from a 2010 state trooper car now I just need to get the rear end what year rears from a explorer will fit our trucks mine is a 72 longbed. I know someone who has a 2004 explorer 8.8 with disk and 3.73 will that fit what year range explorers do I need to look at. By the way good work on this truck.
junkyardbuilder69 wrote:Great job, the shock mounts look great along with the rest of the truck, what color you plan to paint it or is that something you still thinking on ?
Those did turn out nice. I've been thinking about what I want to do with my shocks too. I was thinking about slicing my stock upper mounts and bending/ rewelding them so the shock was straight inline with the frame and then building a lower. Hadn't thought about going to a shaft mount style shock. That looks really good.
i like the spare tire carrier idea...I can't remember though, are you using a rear mounted gas tank instead of the stock in cab? If so, are there any clearance issues for the spare tire?
ionlyswingping wrote:Great looking truck! I read over this and I know it has been quite a while since you cut 1.5 coils off the front to get your current height. Can you tell me if you noticed a lot stiffer ride and were you able to get a decent alignment as to not rip up tires with the camber issues?
Thank you.
Bigblock514 wrote:I picked up a short box today. So just how much did you have to cut out of the frame exactly? Are your rear wheels centered in the wheelwells?
