1970 F250 4X4 Rebuild / Updating
hfdco4
Re: 1970 F250 4X4 Rebuild / Updating
Post by hfdco4 »
Had some welding to do on the axle housing. It was just for aesthetics, there was some pitting that showed once I started cleaning that I didn't like. Now that is done I can finish off the grinding and sanding, then pull the axle shafts and brakes. Then a coat of paint and get the new U-Bolts and cleaned brackets installed. Hopefully I can have it hung from the springs by next Friday and start cleaning the front axle.
:fr: FE390PC
hfdco4
Post by hfdco4 »
Got the rear axle broken down, re-installed the hubs and wheels. Wheeled the axle out of the garage and power washed it. Came out pretty good. The axle is in good shape. Hope to get it sanded and painted this week. Also got the front axle power washed.
:fr: FE390PC
hfdco4
Post by hfdco4 »
Got the rear end painted and found the yoke is damaged. Did locate a new one on Amazon and a guy on FTE is looking to see if he has one. I am hoping for the later since that would be cheaper.
:fr: FE390PC
Manny
Post by Manny »
hfdco4 wrote:Got the rear end painted and found the yoke is damaged. Did locate a new one on Amazon and a guy on FTE is looking to see if he has one. I am hoping for the later since that would be cheaper.
What yoke you need a d60 rear yoke. Spines? etc i have some laying around. :thup:
hfdco4
Post by hfdco4 »
Got the replacement yoke from a buddy on FTE. Got the axle painted and set in place finally. Also got the front axle started.
:fr: FE390PC
hfdco4
Post by hfdco4 »
Here is a pic of the new Yoke!
:fr: FE390PC
hfdco4
Post by hfdco4 »
Got more done today. Painted the U-Bolts and the U-Bolt plates and got the installed. Also removed the stand from the rear of the frame FINALLY!
:fr: FE390PC
hfdco4
Post by hfdco4 »
Got more work done on the Front axle too. Removed the Tie-rods and the top nut on the Ball Joints.
:fr: FE390PC
Manny
Post by Manny »
Looking great curious to know how tall your frame will be sitting with new stock springs and all when you get done. Keep it going your almost to a roller!!! :thup:
hfdco4
Post by hfdco4 »
I am shooting for about 2 inches over stock. That replaces the rear 4" blocks and hopefully gives it an even ride.
:fr: FE390PC
Manny
Post by Manny »
hfdco4 wrote:I am shooting for about 2 inches over stock. That replaces the rear 4" blocks and hopefully gives it an even ride.
Sounds like what I am hunting too. Thinking 2" is perfect. Sorry in advance for copying you if it works out perfectly!!! :lol:
hfdco4
Post by hfdco4 »
Replication is the most sincere form of flattery my friend! If you have any questions let me know and I will try and assist if possible.
:fr: FE390PC
Manny
Post by Manny »
hfdco4 wrote:Replication is the most sincere form of flattery my friend! If you have any questions let me know and I will try and assist if possible.
Definately will hit back with you as time goes by. Ride height and tire size is like my biggest argument i have with myself on the highboy. :cry:
67Step4WD
Post by 67Step4WD »
Great thread and great truck! Can't wait to see the outcome!
67 F100 SWB 4WD Custom Cab (In Progress)
1965 Lincoln Continental Convertible
1972 Fiat Spider
1963 MGA
1966 Chevy G10 NoDoor LS Swap
2006 Buell 900 Wide Rear, Chain Drive Short Track Geared
2013 Audi S4 Tuned
1965 Sunbeam Tiger
Way too many other projects.....
Opportunity is missed by most people because it is dressed in overalls and looks like work. -Thomas Edison
hfdco4
Post by hfdco4 »
I have 37-12-16.5 military tires I am going to be running.
:fr: FE390PC
