4X4X4 roof console and dakota digital dash
rattlecan
Re: 4X4X4 LET THE GAMES BEGIN!
Post by rattlecan »
That is a cool design. I was also looking at these styles too. The prices are a little high for these bumpers. What do you guys think?
anything worth doing is worth doing in EXCESS!! - Carroll Shelby
70 F-350 4X4 crew
customcrewcab
Post by customcrewcab »
i helped casey load that thing from the blaster on friday. it was pretty funny towing it around down town mesa. did those shock brackets come out sweet or what. :D
http://www.fordification.com/galleries/ ... ?cat=10106
if theres a new way, i'll be the first in line. it better work this time
1970 crewcab 393w afr heads, 6 speed, turbocharged, 6 piston calipers 13" rotors on all 4 corners
rattlecan
Post by rattlecan »
Thanks for the help! I felt bad that Casey had to do it alone. That thing barely fit on the trailer!
Here are some pics of the latest progress.....
lifted the front shackles 3 inches and added a receiver to the new front crossmember
added a permanent trailer hitch in the back
new shock mounts on the axle (really cool design!!)
Welding porting of the project is complete. I will take the cab and bed back off the frame and media blast the underside of the cab and get it ready for paint and strip all the stuff off the frame and paint that as well. More to come......
70 F-350 4X4 crew
PhilthyF100
Post by PhilthyF100 »
i'm loving this build, you're doing outstanding work :D
I may have missed it, but what welder are you using for all the work on the frame? I'm about to do a frame stretch on my '69 F350 (for a ramptruck conversion, currently has an old school wrecker back on it)
1969 F350 wrecker
1975 F100
1973 Falcon hardtop
71PA_Highboy
Post by 71PA_Highboy »
I like the shock mounts, but couldn't use them here. The 'pocket' at the back would just hold the road salt and would be rotted out in a year or two.
Is there drainage at the back?
Very sweet receivers... I will have to do that next...
Thanks for the ideas!
r/
eric
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
rattlecan
Post by rattlecan »
I put holes in each of the shock mounts to allow mud :D and stuff to run out. I was worried about rust outs too.
all the welding to the frame was tig welded with a variable rate welder (a very expensive welder) done at a friends shop.
I will be painting the frame and axles this weekend. :woohoo: pics soon to follow
70 F-350 4X4 crew
rattlecan
Post by rattlecan »
Had some time to get back into the shop and make progresss. while the frame was getting welded on, I stripped the cab and painted the firewall and floor pans. I have also stripped the frame and painted it, those pics are soon to follow.
media stripped the firewall and floor pans
a little primer and viper red enamel ( oh yea it is BRIGHT red! )
70 F-350 4X4 crew
zakt
Post by zakt »
what did you use to media strip it, thinking about doing mine myself.
Todd
1972 Ford F350 crewcab
rattlecan
Post by rattlecan »
Hey Todd,
I thought about doing it myself but it was too big of a project. I took the cab over to prostrip here in Mesa, he always does top notch work. I have stripped a car before by myself, I used 250 pounds of silica sand!! it was a major mess. It is so much easier to have a shop do it. I almost blew up my air compressor in the process.
Rob
70 F-350 4X4 crew
zakt
Post by zakt »
did you then just put it on the trailer and drove it over?? How did they move the cab around??
Todd
rattlecan
Post by rattlecan »
Hey Todd,
It was easy moving the cab to the blaster and back. I bought 4 of those 4 wheeled furniture movers and rolled the cab onto the trailer and strapped it down. I thought it would be harder than it turned out to be.
Rob
70 F-350 4X4 crew
rattlecan
Post by rattlecan »
painted the frame and springs. Good to have it rolling again!
stripped it down to bare frame and prepped it for epoxy primer.
I used eastwoods porcelain satin frame paint. it is tough, very hard to scratch.
springs were painted in cast iron grey enamel
starting to assemble all the goods
70 F-350 4X4 crew
Fordnatic
Post by Fordnatic »
Wow, Looks GREAT!!!!!
55F100
marvin2
Post by marvin2 »
Great work....that truck is gonna be huge.
1970 F100 "Marvin 2" - Crown Vic IFS, 302, C4 (work in progress)
1970 F250 "Leonard" - 302, C6 (project in waiting)
1971 F100 "Walt" - 302, 3-speed on the column (Sunday driver)
2004 Mustang GT "Horse With No Name" - 4.6L, 5 speed (Retired daily driver / Friday driver)
rattlecan
Post by rattlecan »
I am not sure how i am going to park this thing??? :lol:
Thanks for the compliments! I hope to have the bed on this weekend
Rob
70 F-350 4X4 crew
