#02 - Jan. 22, 2007
#02 - Jan. 22, 2007
Here we go again!
This one is going to be fairly easy, I think. Therefore, each forum member is limited to one guess per day.
This item is on all bumpside and dentside trucks, and AFAIK there is only ONE of these on any truck. Tell me exactly where's it's located and what it's used for:
- 71 LONG BED
re: #02 - Jan. 22, 2007
It is located on cowl above the firewall and it holds the washer fluid hose.
John Member #1549
- Sharkdance
Its the clip that holds the steel fuel line on the gas tank behind the seat.
- hoss103
My first post! But I think I know it- looks like the rear axle vent tube clip that clips the tube to the frame rail. I have one for my '69, but the tube had rotted away long ago.
(Now I guess I'll have to go introduce myself in the newbie section)
- 71 LONG BED
Oops, I wanted to put another guess and remembered only one per day, shoot.
I think I know what it is now, too!
John Member #1549
- cathynkeith
located on passenger side, clip holds the pos battery cable.
http://s115.photobucket.com/albums/n292 ... type=local
Life is good...... when nothing is wrong that money can't fix.
1969 f100 flareside
1962 ECONOLINE TRUCK (done)
1975 Nova (almost done)
1969 f100 flareside
- theskytoucher
It the clip that holds the wiring harness to the frame at the rear of the truck just before it branches up to go to the taillights!!!
-Troy-
1996 Dodge ram 1500 4x4
1976 Ford F-150 4x4
Quando Omni Flunkus Mortadi
When all else Fails Play Dead
1976 Ford F-150 4x4
- 71 LONG BED
Are you sure there is only ONE on every truck?
John Member #1549
- kknip
Re: re: #02 - Jan. 22, 2007
hoss103 wrote:My first post! But I think I know it- looks like the rear axle vent tube clip that clips the tube to the frame rail. I have one for my '69, but the tube had rotted away long ago.
That is what I think it is.If you are right hoss103,you have to share half your winnings with me!
oh yeah,It would go on the second to the last cross member,right over the diff.
Soitenly! Oh,a wiseguy!
You knucklehead!
65 Mustang
72 F250 Camper Special
You knucklehead!
65 Mustang
yea i think your right there is more than one of those types of clips on our trucks. this must be a special one. i will tell you tomorrow71 LONG BED wrote:Are you sure there is only ONE on every truck?
- chips68
I agree with sharkdance its the clip that holds the fuel line to the tank
holds a heater control cable
OK, here's the deal:
The clip specifically pictured above was the one mentioned by fordman, as the clip that holds the speedo cable to the frame. However, I also forgot the factory used the same clip on the rear axle tube vent, as mentioned by hoss103.
I checked on the only truck I still have that semi-complete, but there wasn't a similar clip holding the line to the fuel tank inside the cab. I'm not saying there wasn't supposed to be one there...but right now I can't recall one being there. And if there IS supposed to be one there, isn't it dipped in liquid rubber, to act as a vibration dampener? However, even if it wasn't dipped, and is a straight metal clamp, the grease on the one pictured above would be a hint that it wasn't inside the cab. (Yeah, I know, it's a technicality...)
I also believe that any clamp that held wiring, brakeline or fuel line was either plastic or a metal clip dipped in liquid rubber...I don't think they used a straight metal clamp on those items, to minimize chafing.
So as it sits right now, I'm going to call two winners of this one...fordman and hoss103. However, if more than a couple of you can verify that this metal clip (without a rubber insulator) is present on the in-cab fuel line and/or the positive battery cable, then I'll have to divvy this one up among those who answered as such....and I'll have to be a little more aware of what I post in the future!
Nice job, you all!
Nice job, you all!
- rjewkes
I was thinking they used one on the frame to keep the e brake cable from wondering over towards the speedo cable and tranny linkage.
fuelly.com
fuelly.com
