coil wire upgrade?
RebelRider
coil wire upgrade?
Post by RebelRider »
Can you replace the resistance wire that feeds voltage to the coil with a resistor? The insulation on mine is about shot.
Torque....God's gift to tire dealers!
Dave
Image Image
http://www.fordification.com/galleries/ ... ?cat=10571
68F250
re: coil wire upgrade?
Post by 68F250 »
Is it the coil wire in the engine compartment? If it is, that's just plain wire. If it's the resistance wire under the dash in the harness, you can buy resistance wire to replace it at the auto parts store, look for 1.3 ohm resistance wire.
You can also replace the resistance wire with a ballast resistor. A regular resistor is not the same, the resistance wire and the ballast resistor have a positive tempco (temperature coefficient). As it heats up, the resistance goes up. It's a compensation factor built-in to regulate the coil voltage. You need this for a couple reasons, when an engine idles the coil is in saturation and heats up but a positive temco will heat up and cut down the voltage. When the engine is turning rpms, the coil is out of saturation and the temco cools down allowing more voltage to the coil. Same thing happens with the supply voltage from the battery, with high charging voltage the temco heats up and cuts down the excessive voltage. When the charging voltage comes down the temco cools and allows more voltage.
Even if you did use a regular resistor and ignore the tempco, it would have to be rated at least 25 watts.
Barry
RebelRider
Yes it's the wire under the dash.
Thanks for the info Barry!
Dave
Image Image
