setting up an oil pressure gauge
bigman78
Post by bigman78 »
So I bought an aftermarket 3 gauge pod. One of the gauges is an oil pressure. So my question is where do I hook up the small plastic hose that it came with? Its got a few different sizes of hook up peices.
1967 F-250 4X4 Highboy, 429, D60 rear, D44 front, NP435 trans, Dana 24 T-case, PTO winch
http://profile.myspace.com/index.cfm?fu ... =136460833
http://www.fordification.com/galleries/ ... ?cat=10577
flyboy2610
Post by flyboy2610 »
It should hook up in the same place as your stock oil pressure sender.
Red Green
you'd better be right.
wt4speed#2
Post by wt4speed#2 »
If it were me I would spend a few bucks and use copper the plastic always seems to come apart (in my case anyways ) when I'm dress to the nines going to a meeting or court or something
Tony B.Image
DFW Area
"Someday...
I hope you to get the chance,
to live like you are dying"
Member#'s 236 & 403
Úlf the Comedy Sidekick
'69 F-100 "Stepper"(currently in a bigillion pieces )
wt's ride
thebucket
68F250
re: setting up an oil pressure gauge
Post by 68F250 »
Fortunately your hose doesn't have too far to go, iirc the 429 sender's on top of the back of the block behind the intake next to the firewall. 1/4" x 18 thread for the sender hole, the fitting should just screw in w/ some teflon tape. The other fitting goes on the gauge. Follow the instructions for inserting the ends of the tubing into the fittings, I believe they are compression style. Don't kink the teflon tubing and give it a little slack. Run it thru the firewall grommet used by the engine wires and make sure it doesn't rub or catch on anything like the throttle linkage.
Barry
RebelRider
Post by RebelRider »
If you use plastic tubing, make your cuts with a good razor so they come out straight and clean. :thup:
Torque....God's gift to tire dealers!
Dave
Image Image
http://www.fordification.com/galleries/ ... ?cat=10571
jor
Post by jor »
These photos show both the electric and mechanical hooked up together and the stock electrical only. If you want to run only your new gauge, just screw in your plastic line in place of the stock oil pressure sending unit.
jor
wt4speed#2
The incident with the plastic line becoming separated, on the passenger side of the firewall I might add was pretty humorous. The PO had some pretty shabby wiring done under the dash. It wasn't sheet metal that cut the line . I was going to a staff meeting and hit a rise in the road , running late as ususal, had a wire short and burn and fell across the oil pressure line burned it in half . within about 25 seconds thought I had wet my self felt warm and fuzzy down my left leg and foot .Ruined a brand new pair of Wrangler reatta's (freshly starched I might add) and a $100.00 pair of Polo Chucka boots . Time I could turn off the key it was too late. Didn't loose enough oil to burn up the damn motor tho.Oil pressure gauge hasn't worked since ,but when she fires next time she'll be reading oil pressure through copper
Tony B.Image
DFW Area
"Someday...
Member#'s 236 & 403
wt's ride
thebucket
Supermike
Post by Supermike »
lol
Guess you'll buy black wranglers from now on!
Former owner of a '67 F100 Camper Special
Current owner of a '06 F150 King Ranch 4x4 SuperCrew
bigman78
Post by bigman78 »
Alright, thanks for all the help!
bigman78
Post by bigman78 »
So is this what you guys are talking about? It sits behind the block and down a little. If so, does it screw off and thats where I screw in the new fitting? Thanks for any help.
68F250
Post by 68F250 »
Yep, that's it!
Don't grap it and start turning, it'll break. Find the right size open-end wrench down where it threads in.
Barry
bigman78
Post by bigman78 »
Ok! Thanks for the help.
19674x4
Post by 19674x4 »
dang, i wish mine were that easy to get to. on the 352, it's under the powersteering pump next to the fuel pump. so i have to pull the powers steering pump, and everyhting to get to it.
My Photo Album
