Bypass or remove the resistor wire?
- xMAJORx
Im stalling an accel breakerless dist. and coil. The instructions say to remove, or bypass the resistor wire. How do I do that? What does the resistor look like?
Before I put the new engine in the truck it had a points conversion kit on it.
What's the best way to do this? I'm not a wiring guy.
re: Bypass or remove the resistor wire?
Dont know, but that is a good looking engine!!!!!!!!!!!!!!
- xMAJORx
yeah but what a trade off!!!
- lrjetmech
The resistor wire is a pink (yes, pink) wire coming off your ignition switch. It goes over to a connector that goes out to your coil, along with your oil pressure and coolant temp wires. I had to remove this wire when I installed my Pertronix II system!
USMC, '83-87
'69 RANGER, Shortbed, 360, Manual, mostly restored already, LOVE IT!!!!!!!
http://www.fordification.com/galleries/ ... ?cat=11813
USMC, '83-87
- heep70
I bypassed mine putting the Petronix in. Just ran another wire from the same plug space as the resistor wire off the ignition plug. In case I needed to switch back to points.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
- xMAJORx
- xMAJORx
Here are some pics. I don't see a pink wire going into the ignition. But I do see one that leads to panel light just above my parking brake.
- spartman
- xMAJORx
- xMAJORx
Which ignition plug? The one that comes out of the firewall? Or at the key cylinder?heep70 wrote:I bypassed mine putting the Petronix in. Just ran another wire from the same plug space as the resistor wire off the ignition plug. In case I needed to switch back to points.
We really need a tutorial about this.
I was think of just running a wire from the battery to a toggle to the coil.
Here are a couple closeup pics of the resistor wire. Notice how it's specially marked as such.
I wouldn't remove it, just by-pass it, in case you ever decide to reinstall the points.
- lrjetmech
When I installed my Pertronix II, I ran a new wire from the solenoid to the center of the dash; made a two-way splice; ran one of the wires over to the ignition switch to replace the pink resistor wire and the other one out to the coil. I replaced the wiring because mine was kinda ragged, plus the Pertronix II instructions said to remove the resistor wire to make sure the module got a full 12V!xMAJORx wrote:
USMC, '83-87
USMC, '83-87
