turn signal
- 1970FordTK
turn signal
Ok newbie question time, I have check and replaced all the bulbs in the lighting system. Everything works expect the left turn signal, both lights on that side light up but no flashing. Just light up and stay on. The four way flashers work and the right turn signal works, seems slow but it does work. I have everything else working expect this for the lights, any ideas?
- ToughOldFord
re: turn signal
Your flasher's bad. The turn signal system and the 4 way system each have their own flasher.
- ratfink
re: turn signal
I would guess the turn signal switch in the column.
Ratfink
Ratfink
Dennis
1968 F100 Ranger 390/ C6 (Mine again)
2008 Toyota FJ Cruiser Sandstorm
2007 3500 4X4 Dodge Cummins
Idleness is the mother of all vices.
- 1970FordTK
re: turn signal
Thanks for the info guys, where is the second flasher located ?
The factory a/c stuff is in the way to look under the passenger side for it. I know where the easy one behind the cigar lighter area is dang thing was hanging below the dash when I got it.
I love this place, questions answered in under an hour
- theskytoucher
re: turn signal
I believe the other flasher is behind the instrument cluster!!!!
-Troy-
1996 Dodge ram 1500 4x4
1976 Ford F-150 4x4
Quando Omni Flunkus Mortadi
When all else Fails Play Dead
1976 Ford F-150 4x4
- 1970FordTK
re: turn signal
Roger that, will look as best as I can. Thanks for the info.
- 1970FordTK
re: turn signal
Right where you said it was, and it was the problem. Going to replace the instrument panel lights while I'm in there. Thanks.
