air hydraulic jacks?
Supermike
Post by Supermike »
Just curious what you guys think of the hydraulic bottle jacks that hook up to your air compressors? Do they work pretty well?
I ask because Harbor Freight has this one for $70 right now, which seems to be a steal for a 20-ton jack! By comparison, a 20-ton at Sears is $279! It looks like better quality, obviously, but worth $210 more? Also, while the minimum height on the Sears jack is about 3/4" lower, the max height is nearly 1-3/4" lower.
20 ton maximum load capacity; Minimum height: 10-1/4"; Maximum height: 20" with screw extension, 16-1/4" without screw extension; Operating pressure: 90-120 PSI; Ram travel: 6-1/2"; Overall base dimensions: 9"L x 5-3/16"W; Air fitting: 1/4" NPT with quick release
http://www.harborfreight.com/cpi/ctaf/d ... mber=95553
Also found this one for a similar price, which looks more like the one Sears sells (I know they don't make all their own stuff):
http://www.mytoolstore.com/astro/asthyd01.html
Here are a few others I've seen, including the sears ones:
http://www.harborfreight.com/cpi/ctaf/D ... mber=41487
http://www.harborfreight.com/cpi/ctaf/D ... mber=94487
http://www.sears.com/sr/javasr/product. ... Cookie=Yes
http://www.sears.com/sr/javasr/product. ... dffidfno.0
Former owner of a '67 F100 Camper Special
Current owner of a '06 F150 King Ranch 4x4 SuperCrew
Thunderfoot
re: air hydraulic jacks?
Post by Thunderfoot »
I too hope someone has info on these as I have thought of getting one of the HF ones to lift my 1ton CC dually. I get tired of pumping that handle on the manual 20ton jack I have, it moves real slooooow per pump...
Shayne
72hiboy4x4
Location: As far away as I can be from Wa state, without crossing the Mississippi
Post by 72hiboy4x4 »
I have one of these, bought it at a tool sale for like $100.00.
I use it almost exclusively at the shop, but it does have its limitations.
It uses a LOT of air, but will lift anything I need it to.
Little limited on versatility and the lift isn't that great (mulitiple lifts to jack up the Jeep high enough to work on the axles)
But it is the only one I have used, other than my Hilift jack...Can't live without it!
hardtailjohn
Post by hardtailjohn »
I have a pair of them and LOVE them!! I use them for setting the crusher and it's sooooooo much nicer than having to pump that handle!!!! :thup:
JH
Never trust a grinning idiot holding a big hammer!
Supermike
Post by Supermike »
Thanks for the feedback! Now the question is, is Sears really worth that much more, or are you paying $200 for the name?
theskytoucher
Post by theskytoucher »
We use them at work (tire store)all the time on the semi's and they work great!!!!!!! just remember when jacking anything up to put the jack stands underneath!!!!!
-Troy-
1996 Dodge ram 1500 4x4
1976 Ford F-150 4x4
Quando Omni Flunkus Mortadi
When all else Fails Play Dead
Thunderfoot
Cool 8) I think I will be getting one myself from the local HF before winter, when I need to change my wheels again. I've gotten some of there floor jacks before and they work fine and you can't beat the price on the jack stands when they are on sale :thup:
Shayne
Thunderfoot
Dustin,
You got a picture, or a link, or something as to what these Mechanical house jacks look like? So I know what to look for… Thanks!
Shayne
averagef250
Post by averagef250 »
Here's one on evilbay... There are several styles, but this is the best one I've found. http://cgi.ebay.com/TWO-WAY-15-Ton-SIMP ... dZViewItem
Another cool thing is they work in any direction. On thier side, upside down, doesn't matter.
If you run across one at a garage sale for $20 don't let it slip by!
Thunderfoot
Thanks Dustin, I’ll keep an eye out for one :thup:
Shayne
