Lincoln 445 or 455? power unit. Price?
two-bit
Post by two-bit »
The company i work for is liquidating some of there extra welders.
they have these power units made by Lincoln. The model # is either 445 or 455 i can't remember.
Any body got a good idea what this might be worth? Its a closed bid sale situation. Sooo. Kinda hard to tell what they are looking to get out of them.
Currently set up for 3ph, 480vlt.
Thanks
Two-bit
Living life full throttle on the North Coast of America!!!
72' F-350, DRW, 360, NP435, Dana 70, 159" WB, P.S., P.B., 12' flatbed, 10,000 GVW.
3ph is worthless unless you have that power at your house / shop. Sounds like a bigger machine (too lazy to search for specs)
Jamie
averagef250
Post by averagef250 »
If it's got copper coils bid $20 on it and scrap it. 3 phase supplies are the best welders you can get, but you can't run 480 3 phase at your house without a $10K converter.
spartman
Post by spartman »
Can a person even have 3 phase power wired at home?
Thunderfoot
Post by Thunderfoot »
spartman wrote:Can a person even have 3 phase power wired at home?
Most residential areas don't have access to it... You have to be next to major main power lines or a business area... And the cost to have it run in if it is even a little ways is OUT of SIGHT :lol:
Shayne
spartman
Post by spartman »
I see
gbrett
Post by gbrett »
you can build a rotophaser for mabey a cpl hundred just depends on how big of one you need and you can only make 240 low voltage 3 phase from your house
