Starter Question
swschulke
Re: re: Starter Question
Post by swschulke »
Update: Got the starter to turn with a direct hot to the solenoid post but i still cant get the key to turn it i guess the switch is bad.
the problem was the wire was not the proper gauge and would not carry current i am guessing...
now to just get the key to turn it!!!
(PS Seeking Mobile Mechanic in the BIG BEAR CA Area)
Black 1971 F250 Sport Custom 390 Engine.
I have no idea what i am doing please help me!
Seriously,I just bought this for 500 Bucks and some tools from Kmart. I Have very Little Auto Experience. Any Advice is needed. I have to make it run...
ttyR2
Post by ttyR2 »
I didn't see anyone mention it, but you might use a test light or volt meter, pull the wire off the S terminal on the solenoid, and have a buddy turn the ignition switch. If you get a full 12V+ on that terminal, or the test light lights up, the solenoid should be getting power correctly from the ignition switch. It's even possible that the ignition switch itself is bad. The wiring on these trucks is pretty simple. Shouldn't be too hard to trace the S terminal wire back into the cab.
Jeremy
1971 Ford F250 CS, SC, 2X4, 390, C6
