Dual horns
Dual horns
Here's a dumb question: did the trucks equipped with a dual horn setup have two of the same or did they have a hi-lo setup? Are they marked?
- Heavenlyfire
re: Dual horns
what, your asking a question??? My grandpa had one that had a hi and lo but i never looked to see if they were marked.
- 68F250
re: Dual horns
Yeah they are both marked. The passenger side has the low horn and the driver's side the high one. The marking is on the outside lip of the horn bell and there's another one 180* from it. The low horn has an extra turn of 'tuning' for the lower pitch.
Barry
re: Dual horns
Yep, you're right Barry (as if there was any doubt). I started digging around the parts boxes of stuff from the F250 Camper Special, one which I knew came with a dual horn setup. They were indeed marked...and the spiral pattern goes in an opposite direction too, for quick ID.
re: Dual horns
Wouldn't that make the sound cancel out?
I keed, I keed.
I keed, I keed.
Jeremy
1971 Ford F250 CS, SC, 2X4, 390, C6
- 68F250
re: Dual horns
You're not that far off, it's called active noise cancellation.
Now if you could just work out the phasing.....
Barry
