Carb size
NUTNDUN
Carb size
Post by NUTNDUN »
Hi gang,
This is my first post and I had a question regarding what size carb to go with. The truck is a 72' f100 shortbed 2wd. The motor is a redone 351w stroked to a 398. It has 11:1 comp, twisted wedge high port heads, mechanical roller rockers 1.7, 2" primary full length headers, super victor intake, the cam is being swapped out for something a little milder but not much. The cam that was in it was a thumper for the drag strip in a mustang with some crazy lift and duration. I don't know the exact specs on the cam that we are going to go with yet. I wanted to see if I could get some suggestions on what size carb, it is a square bore. My one buddy thinks I should put a 1050 on it but I would think that it would be overkill. Maybe an 850? I also don't know what size stall converter yet either. It has a c-6 and I am guessing somewhere in the 4,000 range.
George
72 F100 SWB
398W stroker
My427stang
Re: Carb size
Post by My427stang »
Certainly a healthy motor.
850 or 1000 (or 1050 Quickfuel) all run about the same size with 1 3/4 plates and very little difference in venturi size. All of those would work well. The numbers are all advertising numbers
Another option would be what they call a 950, its a 750 body with an 850 baseplate.
I personally would would go with a QFT or AED 950, stay away from the Holley HP series, I have had nothing but metering block calibration problems.
One comment on your hint to a possible cam swap. Be ready that if you swap cams, with 11:1 you need late enough cam timing to manage dynamic compression ratio. Its real tough to have any compression and mellow out the low end. As a reference, with 10.7:1 compression in my Mustang, I needed a minimum of 288 advertised duration intalled at 106 centerline, you'll need at least that, and maybe slightly later centerline if you decide to go milder than what you have.
NUTNDUN
Re: Carb size
Post by NUTNDUN »
I wouldn't mind keeping it wild with the cam but I am guessing the cam I have wouldn't be right because of the weight differences. The motor was built for outlaw class I think and had to be under 400 cu. The car it was in before it was freshened ran mid 8's. I wouldn't mind using the cam I got with the motor but do you think it would be too much for the truck? I will try and get some numbers from the cam, it is all sitting down at my buddies place. I do know it was a crane cam with 270+ lift I believe. I forget what the duration was.
What about proform carbs?
I forgot to mention that we had the pistons fly cut to lower the compression. The compression was at 14:1 with the above mentioned cam but I didn't want to be buying racing gas all the time. So we had the pistons flycut to flattops.
I apologize for not knowing exact numbers, I have been out of hot rodding for so long I forgot everything. Now I just know enough to get my self in trouble and spend money LOL.
George
72 F100 SWB
398W stroker
NUTNDUN
Re: Carb size
Post by NUTNDUN »
I got the cam specs.
it is a crane cam with a 106 centerline.
intake is 276 @ 50 with 672 lift w/1.6 roller rockers
exhaust is 279 @ 50 with 672 lift w/1.6 roller rockers
The cam is a little wild to be in the truck but I am trying to get the truck back together on a budget and I plan on swapping the cam out later if it turns out it just aint right.
I contacted the one fella at prosystems and he recommended a 4150 with 830 real cfm on the wet bench.
George
72 F100 SWB
398W stroker
willowbilly3
Re: Carb size
Post by willowbilly3 »
It sounds like a screamer and since it does seem to be purpose built for that I would say 850 min. Maybe a pair of 600
