360 conversion (see: please don't kill me)
Okay, the other day I started up my bump for the first time in a year and moved it into my carport. During that process I noticed that an absurd amount of oil was burning out the back. therefore I have decided to start a conversion and what I hope will be a successful 360 to 390ish conversion. (fingers crossed)
seeing as the truck doesn't need to move anywhere anytime soon, I figure since I'm tearing down the engine anyway i may as well make some upgrades while I'm there.
the engine as it sits now:
Now what I would like to do would be to build a decent street motor capable of driving my drag bike to the strip and back. so from the information that I've gathered here, i can say that I need the following:
- New rotating assembly (crank, rods, pistons, bearings, etc...)
- Block machine work (align hone, bore, deck)
- new gaskets
- new bolt kit
what I want:
- New heads or port job on old heads
- new intake manifold
- 4v holly
- headers
- electric water pump
- electric fuel pump
- larger oil pan
sounds ambitious I know, but i've got time.
- new gaskets
- new bolt kit
what I want:
- 4v holly
- headers
- larger oil pan
If you are going to tell someone the truth you had better make them laugh otherwise they'll kill you.
- George Bernard Shaw
- court1100f
Re: 360 conversion (see: please don't kill me)
Hey Brother I'd axe the 390 plan in favor of a 410Cid Plan 415 if you bore it .030 over or at .040 a 416-417 the only part in your list that'd need modifying is the crank stroke. to get your 390Cid you'd be getting a 3.78" stroke crank all that'd be needed to go with a 410-417Cid would be a 3.98" Stroke crank like was found in stock 410s and 428s and with that longer stroke(Read as the same stroke as a 300 Straight 6) you'd get butt loads more torque not to mention the old addage no replacement for displacement
- sideoilerfe
Why do you need a larger oil plan? yours will work just fine.
1970 F250 4x4 390/4spd
1968 F250 4X2 360/C6/No Rust!
- Wes
You will also need the 428 balancer and flywheel, 2 different weights available depending piston weights.court1100f wrote:Hey Brother I'd axe the 390 plan in favor of a 410Cid Plan 415 if you bore it .030 over or at .040 a 416-417 the only part in your list that'd need modifying is the crank stroke. to get your 390Cid you'd be getting a 3.78" stroke crank all that'd be needed to go with a 410-417Cid would be a 3.98" Stroke crank like was found in stock 410s and 428s and with that longer stroke(Read as the same stroke as a 300 Straight 6) you'd get butt loads more torque not to mention the old addage no replacement for displacement
Wes
67 F250 High boy
69 Bronco
If you can't see fit to stand behind Our Troops...Please stand in front of them
67 F250 High boy
69 Bronco
- willowbilly3
Sounds like a cool build. Not sure I would do the electric water pump for a road truck. Most of them didn't used to recommend street use, haven't studied it lately though.
I notice the valve cover has the silver emissions sticker. Is that the original? My 1970 car 390 has a silver decal too, I thought truck ones were orangeish but maybe that was later. Just curious.
- court1100f
Fair enough Could you have it internally balanced or would balancing and blueprinting alleviate the weight offset???Wes wrote:You will also need the 428 balancer and flywheel, 2 different weights available depending piston weights.court1100f wrote:Hey Brother I'd axe the 390 plan in favor of a 410Cid Plan 415 if you bore it .030 over or at .040 a 416-417 the only part in your list that'd need modifying is the crank stroke. to get your 390Cid you'd be getting a 3.78" stroke crank all that'd be needed to go with a 410-417Cid would be a 3.98" Stroke crank like was found in stock 410s and 428s and with that longer stroke(Read as the same stroke as a 300 Straight 6) you'd get butt loads more torque not to mention the old addage no replacement for displacement
- DuckRyder
Yes, you can internally balance a 428 crank. It will take a few chunks of mallory metal which will add to the cost.
- tybob81
Itshard to find a good 428 crank with out spending an arm and a leg. Survival or blue thunder make stroker cranks for fe's that might be an option for you also.
I was thinking about using something like this.
http://store.summitracing.com/partdetai ... toview=sku
so what would it take to make something like this work, other than a cylinder bore and a re-deck?
- tybob81
That kit would work well. Summit is always a good place to get your go fast goodies and they have excelent customer support.
- convincor
you mat as well go to the 4.25" kit from Survival and it's already balanced.
http://www.survivalmotorsports.com/FE-Engine-Kits.html
And Barry's customer service and knowledge will far exceed Summit's..
"Still Plays With Trucks"
- convincor
Also, new 428 cranks can be had for just over $500 these day's.
http://cgi.ebay.com/ebaymotors/ws/eBayI ... &viewitem=
crank & rods
http://cgi.ebay.com/ebaymotors/Ford-428 ... .m20.l1116
Another crank
http://cgi.ebay.com/ebaymotors/BRAND-NE ... 240%3A1318
crank & rods
Another crank
sideoilerfe wrote:Why do you need a larger oil plan? yours will work just fine.
to be honest i'm not entirely sure that I will need one. but the reason I thought of one was because of this article http://www.carcraft.com/techarticles/cc ... index.html
seemed like a good idea.
- Wes
Yes drag racing a fe w/o some sort of oiling consideration will starve the engine for oil on launches. I new a guy raced a super stock 428 mustang, rules didn't allow for other then stock pan. His solution was to add an extra quart when at the strip. This seemed to very well for him 1 motor made it 2.5 seasons.
Wes
67 F250 High boy
69 Bronco
67 F250 High boy
69 Bronco
yeah I wasn't planning on drag racing the bump. But I figured, since I'd be down there and adding a windage tray I may as well put a new pickup and pan in place as well.
