Grille polish
69 Camper Special
Grille polish
Post by 69 Camper Special »
Does anyone know of a good polish for a 69 Ranger aluminum grille? The grille is straight, just oxidized badly. I hate to try anything not specifically for aluminum for fear of ruining the finish altogether. Also does anyone know the exact name for the color red on the horizontal center bar? Source for paint? Any help is appreciated.
Jody Crabtree
"Dad's old truck"
69 Camper Special
re: Grille polish
I think I may have found it. A friend put me in touch with a friend who owns a metal refinishing place. He suggested Windex (blue) and CHEAP aluminum foil balled up. Spray on the Windex, rub with the balled up foil. tried it last night on one of my headlight doors and it seems to work. It will take a lot more work, and needs to be followed with a bit of metal polish to take some more black off that comes in the process. Before anyone else tries this, let me keep trying it on my piece. That way, if it turns purple or something, We've only lost one original piece. I will let you know how it turns out in a few days. I set it outside on the porch today to see how it stands up to Georgia heat today.
Jody Crabtree
"Dad's old truck"
OldBlue67
Post by OldBlue67 »
thats wild I've never heard that before! definitely let us know how it works for you
~Liz
Old Blue Truck is Old and Blue
Ugly as sin but dont get in my way VA-ROOOOOOMMMMM!! :evil: :evil:
69 Camper Special
re: Grille polish
The aluminum foil thing seems to get light oxidation off the aluminum. A lot of elbow grease involved. Not sure it is worth the effort. Doesn't seem to hurt the aluminum though. If anyone hears of anything else that works, let me know.........
Jody Crabtree
"Dad's old truck"
cobraF100
re: Grille polish
Post by cobraF100 »
Check with WillowBilly as I think he had found some Good info that worked
Chris
Never Forget Our Soldiers
71-F-250SC-72-F-250C
re: Grille polish
Post by 71-F-250SC-72-F-250C »
Neverdull seems to polish alot of things. I used it on my grille and got some of the oxidation off. You can find alot of use out of that stuff.
Stephen
71 f-250 Sport Custom-frame off in progress..again thank to irjetmachanic. :)
72 f-250 Custom
71 f-100 swb sport custom
03 mach1 mustang
cant forget my thing...haha 74 volkswagon thing.
[quote="ToughOldFord"]
Damn, 7 gallons per mile, obviously FE powered!
dotcentral
re: Grille polish
Post by dotcentral »
I have used "wadding compound", and it works pretty good. It is chunks of rough cotton batting with some sort of polishing compound in it. Comes in a metal can. It works great on aluminum, chrome, stainless - or it has for me anyway. Should be able to find it at Lowes, Home Depot, or any decent hardware place.
71-F-250SC-72-F-250C, is Never Dull the same thing? I think the stuff I have has a real similar name.
Former owner of 70 LB SportCustom and a 71 SB SportCustom. Looking for a replacement bump!
GT-Racer
Post by GT-Racer »
I believe that is called Never Dull. The wadding that is. Worked well on my buddy's aluminum radiator. Lotta rubbing though.
'67 F100 2wd shortbed - Beginning restoration.
351w, 5-speed, 3:70 gears (someday)
Drivin' a Chevy is Kinda Like wipin' before you poop, it just don't make no sense....:)
granitestate68
re: Grille polish
Post by granitestate68 »
Mothers aluminum polish is the nuts. Wipe on, Wipe off. Works good for me.
http://www.fordification.com/galleries/ ... p?pos=-550
1996 F250 Slightly lifted 7.3L Diesel
1961 Falcon Ranchero 144 Inline 6
re: Grille polish
Neverdull is the cotton wadding with polish in it.
Stephen
72 f-250 Custom
03 mach1 mustang
dcbullet
re: Grille polish
Post by dcbullet »
I gave it a whirl with some Never Dull. This grill is quite pitted so I did not get a real "shine" with it but I think it's an improvement.
Before:
After:
Before:
After:
Before:
After:
re: Grille polish
Thats how it was with mine, but if you rub on it long enough it will smooth out and look good. The only problem is I dont have the time to do it.
Stephen
72 f-250 Custom
03 mach1 mustang
dcbullet
Re: re: Grille polish
Post by dcbullet »
71-F-250SC-72-F-250C wrote:Thats how it was with mine, but if you rub on it long enough it will smooth out and look good. The only problem is I dont have the time to do it.
Stephen
Even just with the Never Dull? It doesn't seem like it has enough grit to it.
greenbank
Post by greenbank »
If aluminum grilles work anything like aluminum motorcycle engine casings, you can do the whole 200-400-600-800-1000 grit wet-dry sandpaper thing with them, doing a final polish with a buffer. Tedious but you can get an almost chrome-like finish in the end.
1968 F250 Ranger Camper Special
-- 360, AT, PS, PB, disks
-- See Goldie
dduude
Post by dduude »
My question is once you get it shiney shiney can you clear coat it so it will stay that way ???? Dude!!!
http://s131.photobucket.com/albums/p281/tailgaterdude/ 1968 F-100 302 ci, 3" dropped axles ,
'73 Disc Brakes '48 F-1 Roof ,69 Mach-1 hood scoop'92 Caddy Taillights ,4-Track Player
1948 F-1 W/Flat six
